early FJ40 horn relay wiring
Krondor
Greenville, SC
I purchased an early replacement horn relay but am having trouble finding out the correct way to wire it up.
Here is what I am working with:
New horn relay form city racer and a 1965 FJ40 wiring harness with a green white (GW), Green red (GR) and Green Yellow (GY) wire.
View attachment 2653590 View attachment 2653596
Just starting to look at my inoperable horn on my 69 (11/68) build. I know gw goes to the horn itself and gr to the horn button. Gy goes to the fuse panel through RB wire at least according to wiring diagram and as i see it in my 40. Those letters are confusing. Have you tried hooking them up in the order removed? I would try GW to H, GY to B and GR to S. Someone else who is certain hopefully chimes in here and helps us both
Just did this last week. GW twin wires to the horns (H), (B) is battery positive and (S) is the wire to the horn button (it makes a ground when pushed, thus negatively switching the relay on). I forgot which color exactly but think GR went to the horn. Use a test light or multimeter to check which has positive always on power, that goes to the middle.
Those letters seem to be spot on to me: H = horn, B = battery, S = switch.
If there's any doubt in the wiring, a volt ohm meter is your arbiter:
The horn relay wire with 12 volts positive goes to the relay's "B" post. The horn is always energized, so this wire should be hot at all times.
The horn relay wire that has continuity (0 ohms) to the horn connector goes to the "H" post.
The horn relay wire that has continuity to ground when the horn button is pushed goes to the "S" post.
Inside the horn relay, the battery power feeds one side of the relay coil all the time. The horn button provides a ground path for the relay coil when it's pressed, and energizes the relay. The contacts on the relay feed power from the battery power to the horns when the relay is energized.
GR to S terminal, GY to B terminal, 2x GW to H terminal
At least a ‘63 and a ‘65.
@Coolerman
Aka Mark
I got me a mystery.
Have a new cityracer relay. Screwed it to the fender and wired up the 3 wires
So if I wire as shown above, I will blow the horn fuse at the fuse box. So I did an experiment. I unplugged the S ( signal from the horn) and the H (horn wires). It still blows the fuse.
If I do not screw it to the fender, and isolated it with some rubber, then with the same wiring, it will not blow the fuse and the horn works.
@Coolerman
Aka Mark
I got me a mystery.
Sounds like there is a short to the case inside the relay.
I have had some fun with my horn. Maybe this will help? This is the Coolerman test:
Disconnect EVERYTHING from the relay. Using jumpers, apply +12V to the B terminal. Does the relay click? (It shouldn't) if it does then that relay is grounded through the case and is not the correct relay. You can still use it but you will have to isolate the relay case from ground with some type of insulator.
If it does not click then using a jumper, ground the S terminal. Relay should click and you should measure +12V on the H terminal. IF that works then connect the horns back to the H terminal and again ground the S terminal. Horns should blow.
So - to this point. Both City Racer and Vintage Auto Parts Horn Relay both ground the "B" Power thru the relay lever that that touches the out side of the case that is grounded - causing short that blows the fuse.
My application is on a 1975 FJ40 Landcruiser - that 99% of the electrical if factory original and in good shape.
If you open the relay and test the top lever of the relay that is hot and supplies power to the horn when the relay is activated- you will find continuity from the "B" terminal to that upper lever ( that rests against the metal case).
My purpose for this post is to see if I have this completely wrong, and, to get feedback on my work around.
The horn relay is a discontinued item, and either is being made by a supplier or is being repurposed for our application.
The Factory Service Manual shows the Horn Relay grounded. As this relay comes, as far as I can see - in use - it's a short.
Maybe these two relays are missing something that isolates the relay inside?
Am I missing something??
Here are my pics covering the above discussion.
