Test fit went well, except for the PSCG. The sheetmetal shop made the bends in the wrong spot, so they didn't fit. I have a few of the PSCGs from the previous run so, I'll have some full sets ready to ship by Monday or Tuesday.
You should get them by Thursday or Friday. Thanks for the order!Back in Stock & just ordered - look forward to getting it on!
Do you have any pictures of how the bumper mounts near the front crossmember?I just put a full ARB front bumper on my 2016 LX. Are there any compatibility issues with your skid system and your low profile recovery points?
The recovery points will work without issue.Hopefully these are helpful. If not, let me know and I’ll get whichever angle View attachment 4158547
Some modifications will need to be made for the ARB bumper to transition into the front skid. My power steering cooler guard won't be able to be utilized either, but the ARB bumper will protect that.
Have you had any issues with your power steering fluid overheating with that bumper and winch installed? Another member had issues with theirs, I believe they had the same bumper/winch combo.
Hopefully these are helpful. If not, let me know and I’ll get whichever angle you need.
My front skid hugs the front crossmember, it looks like it should fit under the arb section. Mods would need to be made to make each bolt to each other.Thanks for the feedback. Good to know regarding the recovery points. I figured they would work.
The modifications I assume will be on the ARB skid side?
As for the power steering issues, I haven’t had any yet but the bumper set up has only been on for about 100 miles. But it’s summer, I’m in Houston, and I have 600 acres of unpaved, slow, off road type driving at work (think mild to moderate trail rating) so if that’s an issue, I’ll across it sooner than later. That said, there are a few versions of this ARB for the 200 series. Mine is the latest revision/version, so I’m not sure if that’ll help or not. I can always add a proper external cooler if needed. Ironically, I didn’t go with something like a Dissent design because I hate the high clearance cuts where everything is so exposed. I like the actual protection the ARB offers via its coverage and skid plates, plus the bull bar.
Perhaps adding some cut outs or smaller drilled holes to that lower skid plate would aide in airflow?
Does the ARB bumper not have cooling holes below for the power steering cooler? That's too bad as I expect better from them being in the game as long as they have. The Dissent bumpers definitely do. Which could point to a potential solution which is to drill some ports for airflow.
Pics stolen from @radman
Here's a pic of the substantial OEM cooler - which suggests just how much heat the system will put out and definitely needs cooling airflow. The radiator (and integrated tranny cooler) behind that could equally be suffering. Back in my autox days, with the...
Just the PSCG won't be used with that bumper. A little flat filler plate can be made to make for a smoother transition between the 2.Apologies for the "me too" question. Received the skid plate a week or so ago - amazed it fit it in a single box - impressive.
Looking to go with "The Cruiser Company" front bullbar bumper now that TJM's bullbar isn't available. Few pics below. Do you see any interference problems?
Toyota LandCruiser 200 Series Facelift Bull Bar | Australian Made
Australian made Toyota LandCruiser 200 Series Facelift bull bar built from 5mm BlueScope steel. Slimline, winch compatible and built for serious protection.thecruisercompany.com.au
Thanks - and next weekend slated for install!
