Additional fin cooler for steering
VT
Has anyone successfully added an additional fin cooler for the power steering system?
If yes, where did you fit it?
I bought one and brought it to a local mechanic who says he can't figure out where to fit it, given the winch occupying real estate, etc.
My power steering always fails on hot days, especially when wheeling at slow speeds, because the ARB bumper blocks the airflow to the stock cooler.
Thank you,
Jared
Are you sure you need that and that is the issue?
I drive my 200 slow wheeling in the Mojave and it's 107.
With my ARB bumper and winch, it has no steering heating issues.
Where are you wheeling where it's so hot?
I think it's an issue of heat, but I don't know for sure. It doesn't happen on cool days or when the vehicle is driving fast and there is plenty of ram air. But when it's 90 degrees out and, and the vehicle is going a few miles an hour or is stationary, it becomes very difficult to turn the wheels. I think the fluid is boiling.
Mine is a 2014. What year is yours?
You have something else going on. 90° is almost pleasant out, and the fluid should not be "boiling". Mine is a 2015 in Dallas, TX with an ARB bumper and have no issues in the Costco parking lot cruising for a spot. Start with a fluid flush and see if it improves or breaks it. If it breaks it, it was going to break regardless, and should identify the issue.
Linking your other thread.
Thank you for linking the other thread. It is a year later and I am trying to execute the advice from that thread, to add a fin cooler. Now I need to figure out where it has fit successfully for someone else.
Have you taken measurements of PS fluid temp?
Does the ARB bumper not have cooling holes below for the power steering cooler? That's too bad as I expect better from them being in the game as long as they have. The Dissent bumpers definitely do. Which could point to a potential solution which is to drill some ports for airflow.
Pics stolen from @radman
Here's a pic of the substantial OEM cooler - which suggests just how much heat the system will put out and definitely needs cooling airflow. The radiator (and integrated tranny cooler) behind that could equally be suffering. Back in my autox days, with the amount of steering and high rpm on a short track, upgrading the factory power steering cooler was a thing. In certain uses in rocks on hot days at low speed, I can see it stressing the system and putting out a lot of heat.
There could also be other contributors. Aggressive offsets and more tire scrub combined large tires and overlanding weight - that will tax the steering pump more. It's also worthwhile to mention if you aren't already using low range for more engine RPM and fan cooling, to support more hydraulic pressure.
The hydraulic pump point has probably been burned up enough that it needs to be replace. Very likely the seals and/or bypass circuit are compromised and not putting out enough hydraulic pressure. I would recommend replacing it.
Though that still only a bandaid to the original cooling issue that led to this. Consider drilling holes. Or you'll need to relocate the factory cooler higher up so it receives more airflow.
If you need another cooler format to relocate, you could possibly use my tranny aux cooler mod but for the power steering circuit. Any cooler at the current position won't do any good.
I don't think it's an ARB bumper issue. Thousands of land cruisers use arb bumpers without this issue.
I would suggest replacing the fluid if you have not done so. Could easily be just a fluid problem, or some restriction in the flow (like the pump).
Teckis300,
Thank you for this amazing and thorough reply. There is a lot here for me to digest. I appreciate you taking the time to put it together.
Best regards,
Jared
