E-brake
Hey,
I own a 75 fj40 and my e-brake doesn't work The cable is connected but pulling the brake produces no results anyone got any ideas?
needs to be tightened, shoes are gone need replacement? take a look and see if YOU can find anything wrong. had the same thing just needed to be tightened is all
I've never seen an e-brake assembly like his the drum is on the drive shaft right how do I get at it? I don't see an easy way to open it up and take a look....
nothing easy about a cruiser. you need to take off the rear driveline and then you can take off the drum. it sucks i know
Welcome.
There is a 10mm head bolt sticking out the 'case' side, opposite of the driveshaft, that, if you turn, and you still have shoes in there, you will be adjusting the shoes closer to the drum, and then you can pull the lever and see what happens. Hopefully, you are not leaking oil there, and that it is something as simple as this.
Otherwise repairing the parking brake assembly goes something like this...
Removing the driveshaft, draining the transfer case gear oil, removing the drum retaining nut (27mm), pulling the drum off, and rebuilding the parking brake is really not that big of a deal. Have a tourque wrench to get the drum nut(output shaft) torqued back to 125'#s..
Factory Chassis and Body manual is a good thing to have...
Good luck!
-Steve
And when you take the drum off, 90 weight is going to come
running out of the transfer case. Seriously, if you do not
have a Haynes manual (or better yet) the factory service
manuals, you should start shopping for one. There is a small
bolt on the back of the e-brake plate that turns a cam that
pushes the shoes out towards the drum. You should try
adjusting the e-brake before pulling the driveshaft and
drum. Good luck.
I found the adjustment bolt it won't tighten but it will loosen....by turning it counter clockwise am I tightening the shoes or is it the other way around.....yeah I agree that most everything on cruisers is simple.....thats why I have one....(and love it!)....but there are varying levels of simple...hehe....just tring to figure out how much work I have on my hands....thanks for the quick responses and all of the help
Turn it as far as it will move one way and try it. The adjuster could have been put in there backwards at one time, so clockwise, counter clockwise does not really matter if the adjuster moves the shoes and the brake works...
:beer:
Good luck!
-Steve
well it looks like I need to rebuild it I adjusted both ways and no results any suggestions on the best place to get the parts and any tips on rebuilding it would be awesome thanks
I recently shopped around and found CCOT to be the most reasonable and you receive extra gifts for free (I received a mirror once, pedal covers sexy mama posters etc.)
Check for an oil leak so you can order the necessary seal. You'll probably need it
Good Luck
JJB
SOR or CCOT has a complete rebuild kit for around 70.00. Comes with everyting you need inc. the seal that goes between the trans. case and the e-brake.
Ccot $53.00
Inspect the backing plate for grooves where the brake shoes contact the backing plate. I recently rebuilt my parking brake assy only to find that the shoes were stuck in the grooves after years of use. - Simple weld, fill, grind smooth and reinstalled. Understand now why they never adjusted.
