e-brake cable to short now
try rerouting it.
Or get one from a later 4 speed.
I used one from a 4spd truck on mine....then switched it to the floor lever like in the 79 and later trucks....
Good luck!
-Steve
Steve, that sounds like a great idea. It would clean up the under dash and the firewall, too.
I'm guessing just a backing plate for where it goes through the floor?
Ed
The four speed cable that attaches to the under dash lever will work fine...
On the floor lever, there is a different cable that is the better part of 80.00us IIRC, to use this set up, and you may find clearance issues mouting this on the top of the tunnel, between the top of the transmission and the lower part of the parking brake bucket.....I have a body lift, so it was no big deal....I installed this type of set up on a 74-40 a couple years ago, and the lever needed to be placed on the floor....
Me- I would find a longer cable from an 1974 40 series and try that first...The cables changed in 1976, IIRC using a different attachment system, but a similar lever affair...
Good luck!
-Steve
Ed
But then routing a hand throttle and using it while wheeling becomes more difficult..........
I bought Morgan's doubler a couple years ago (SM465/NP203/4-speed TC). Came with a e-brake cable. I heard that Mudrak put it together for Morgan. Also heard that the cable is a heavy-duty OEM cable from Scandinavia or something like that.
Maybe Mudrak remembers where it came from & how he got it.
If you need pics or maybe know where a part number might be on it, let me know, I'll take a closer look at it.
naaw, thats cool, no need but i do appreciate the offer.
jim
I rotated the backing plate about 15 degrees. The original intention was for the cable to clear the VSS on the AA NV4500 adaptor, but the unforeseen benefit is that my e-brake cable has enough slack now.
