Build Dusty Roads - Tilda Bogue Service Station
I've not seen any leaks. Must be some crackhead stealing it
Google the place in Sac.
Georg says tell them the vehicle and that the speedo is 15 mph slow
They do the rest
Gotcha!
Took it to town for a nice romp
3.70s make a huge difference
Atlanta speeds
Speedo is WAY off. @orangefj45 told me about Commercial Speedometer Service in Sacramento that makes a $100 box to fix this. I'll let Darin set that up if he cares.
How does it handle at that speed? How much effect does it have on the low end trail climbing.....say, Colorado
I wheeled my 60 for years with 4 speed and 3.70s. Never an issue for trails. It's never going to be a crawler unless you add an Orion case.
I'm just for the old mining trails outback in the Rockies or deset. I Did the Moab thing a few times in my old jeep back in the late 80's/ 90's and had fun but.....just like the cruising and views now.
Thanks.... May do a gear swap next.
Struck out for Atlanta before dawn. I knew the day would be good when I fell in behind the Pig
Arrived in time to show Darin around his new engine upgrades.
Sheffield showed up with an outstanding smash burger from NFA burger
Off now to pick up a Pig from the body shop then north to grab a 70 series
NFA is literally walking distance from my house and is also almost as elite as some people - yes, mainly family, but still - say that I am. Truly one of the best burgers (certainly smash burgers) that I've had. And don't ask for ketchup on said burger unless you really want to get a s*** stare... sassy sauce FTW.
I was honored he went out of his way to get me one. That was a tasty burger!
That Sheffield guy... he's a real one as my 13 year old son would say...
This one fits clutch and 80 series tops. I have to use the chain thing for 60 series
I’m having trouble getting past the dry, leak test with this adapter. Tried brake fluid on the o-ring. Can only achieve between 5 and 10 PSI while air is rushing out between the reservoir and the adapter.
When rotated, the 3 knobs seem to apply force inwards towards the reservoir lip, holding it in place. While troubleshooting, I noticed without the o-ring installed, the 3 locks secure from underneath the reservoir lip seemingly creating a nice seal but without the o-ring, still experienced leaks.
Is there a trick to sealing this well? Seems like a great tool and I’m just under qualified to operate.
Place the adapter on the plastic housing.
Rotate the 3 legs under the edge of the housing
Turn the center knob tight. Very tight.
Pressurize. Tighten center knob again.
Should hold.
