DUI HEI FI Distributor Alternative
East Hanover, NJ
RE:Dist
I am running one and have no problems with it. the first one I got from them did not fit it needed to be milled a little more when I got it back it sliped right in.
The tape is to mark #1 cyl. I did this.
Chance:wrench:
The one in the pic below is one of 18 I've installed from HEI dizzy and have had no problems... its the best for the $$ you can buy if you want a low cost HEI.....
I called Brian today since he is right around the corner. Really nice guy. He is from Australia and has had cruisers in the past so he knows the 2f.
I'm going to try to go for a visit tomorrow. But from what I can tell he is a good stand up guy.
Am I missing something? It looks like the seller has a TBI dis. or a HEI dis., but not a HEI and TBI combined. I'm just starting to gather pieces for a TBI swap on my 2F, and I was going DUI until I saw Joe's post, but after looking and reading the sellers add I'm a little confused.
Folsom50
The one in the link is a small cap 8-pin HEI module. HEI modules came in 3 flavors. The 4 pin one for non fuel injected, a 7 pin HEI module for Fuel injection(older), and a 8 pin HEI module for Fuel Injection(newer).
There were 2 variants of the HEI Dist through the years. The large cap that had the coil on top of the dist and the small cap that had the coil external.
What you see in that link is a small cap 8 pin HEI dist. You supply the coil for it.
Folsom50
AH! I did not know that, thank you.
Hmmm....
So, how does this distributor stack up against, say, a 60 series distributor in an early 2F? Or, what I have now, an early distributor with a Pertronix? (in an early 2F)
Hmmm....
No clue.
I have used an HEI dist in my old FJ-40 with a '78 2f and the difference between the Toyota one and the HEI was night and day. Don't know anything about the 60 series 2f dist.
Keep in mind that the one in the link is a dist setup for fuel injection. If you want one for carb, go look around in his store. He has one with a large cap 4 pin HEI. I would email him this question as well.
Joe
I ran a DIY HEI in my 74F and had no problems and great performance. When i built my 2F I switched to the big cap FJ60 distributor/coil/ignitor and I am equally pleased. I think the main advantage of the Big Cap is that it is Toyota and the advantage of the GM HEI is low cost and availability of parts.
Ed
Will the 8 pin work with the '87-'93 painless harness? What about the ecm? I called painless and that was like talking to a fence post.
I wouldn't know... I am using a Megasquirt 2. Send these questions to the guy selling it. You can do that through the Ebay store.
