Dual Battery Isolator Choice
S. Ontario
I used a Sure power 1315 100 amp bi-directional smart solenoid/battery seperator. It can run automatically (when it senses 13.2v from the main battery,it parallels the second battery, or with a switch in the dash. I put a 100 amp circuit breaker between the batteries.
http://www.surepower.com/separator.html
I bought mine from an RV distributor on ebay for about $85.00 shipped
Keep in mind that the stock alternator will put out between 90-100amps max.
I like the fact that I can flip the switch and charge the second battery whenever I want or need to, not blasting it all the time with a typical heatsink diode isolator.
I'm planning on using a Wranglernw.com setup. with a controller / solenoid setup which isolates and allows you to combine for emergencies. If the setup for an 80 is not yet on their website call them and ask for Stan. I used their stuff in two prior rigs and loved it. They use MIL spec battery terminals in all their kits too.
I did the same thing, except I just purchased the Wrangler NW isolator and wired it up myself without any kit. It's very simple I have it set up with a three position switch that allows the batteries to be connected or disconnected when the ignition is turned on/off, connected manually, or disconnected manually.
Some people don't like running isolator or solenoid systems with both batteries connected, but if you winch, that's the only way to go. If you don't winch, then running a system where the batteries are completely isolated all the time has some advantages.
I like things that are simple and easily bypassed and easily fixed in the middle of nowhere which is why I went the way I did.
Care to explain the reasoning for those of us less electrically minded? :grinpimp:
my primary-battery runs the following:
vehicle Ignition
regular original-factory stuff like wipers, turn-signals, head-lights, etc...
secondary-battery runs:
on-board air compressor
110v voltage regulator
cb radio
off-road lights
winch (sitting in garage):P
about a year ago, I accidentally disconnected the voltage sensing wire from my alternator.
It took nearly 3days for my primary battery to drain enough that it would no longer crank the starter.
While in disbelief, I hooked-up my jumper-cables from the secondary to the primary battery and started the truck to make it home.
The following morning I found the disconnected sensing wire, and plugged it back into the alternator.
The isolator allows me to design my system...completely isolating both batteries.
I think this is a good thing :D
manny
