This is what I replaced on mine. If you are unable to source one I'd be happy to send this to you for whatever it costs now for me to get another. I immediately ordered one online as a spare after paying a hefty premium at my local lexus dealer when I needed one.My harness is on backorder with no delivery date listed. Time for plan B
Ok, figured it out. Instead of pressing towards the cable, you push away from the cable. The driver side it was easier to just remove the 10mm bolt holding the bracket. Passenger side was super easy once I realized I was doing this the wrong way.2008 Tundra 5.7L here.
The wiring harness clips behind the intake manifold are driving me absolutely crazy. I am struggling to get this released. I taped a screw to the palm side of my index finger in hopes of using this a means of disconnecting the clip. What an absolute pain the arse this wiring harness is.
Question for those who've done this, is the release clip on the underside and does it slide straight back towards the firewall?
Did you happen to find an intake manifold gasket at Toyota? I am trying to sourvce parts I need locally form Toyota and they told me there ar ea couple different part numbers for the intake manifold gasket. ThanksThis is what I replaced on mine. If you are unable to source one I'd be happy to send this to you for whatever it costs now for me to get another. I immediately ordered one online as a spare after paying a hefty premium at my local lexus dealer when I needed one. View attachment 2842634
Yes but I don't recall the part number for it. I originally got my parts from the Lexus dealer and didn't recall an issue with multiple part numbers. If I had to do it again, I'd probably not replace it since my old ones were in great shape but I only had about 70k miles when I did it so YMMV.Did you happen to find an intake manifold gasket at Toyota? I am trying to sourvce parts I need locally form Toyota and they told me there ar ea couple different part numbers for the intake manifold gasket. Thanks
Thanks. What year is your LC200?@Omsok here is that part. Was able to find the old part that I kept in the bag the new one came in. Hope this helps.View attachment 3128017
It's a 2015 LX570.Thanks. What year is your LC200?
I just wanted to jump in here to say thank you.
We recently bought a '21 LX570 with 30k miles. At 32k miles we ran into the same issue. Being so new, and under warranty, we had the car towed to our local Lexus dealer. With only 2 months and 2k miles of ownership, we didn't think it would be a rodent issue but it was. They originally quoted us $1,200 for diagnostic & damage repair. I asked why they couldn't just replace the harness and he said the knock sensors harness is connected to the main harness that runs under the car; it would be $8k+ to pull the motor, labors & parts. I said go ahead and repair the harness. I started doing some research and found this thread & part number.
At the end of the day, they were going to charge me $1,979 for labor in repairing the chewed harness. When I arrived, I asked for pictures of the damage.
According to the service manager, they did all of the work to REPAIR the harness - with warranty on the work - without knowing that there was a cheap & easy replacement harness for that section.So they did use the replacement part or not?
Ah, makes sense. I'd personally prefer the replacement harness but the warranty is good coverage.According to the service manager, they did all of the work to REPAIR the harness - with warranty on the work - without knowing that there was a cheap & easy replacement harness for that section.
Knowing that they could have easily replaced it, they only charged me what it would have cost to replace that small harness. Most of the charges were disassembly/reassembly.
forum.ih8mud.com
There is a coolant hose that runs to the throttle body, so you don't really have to drain the entire system, just enough to get it below that level. It will make a big mess on top of the engine if you don't.currently attacking this fix. curious if you can do it without draining the radiator? anyone try? i bought a harness and 4 sensors so and manifold gasket. thanks
