Driveshaft question
Kansastitty
The rear driveshaft I'm working on has has the sleeve that covers the slipjoint bashed in to the point where it cannot go fully compressed. I just cut it off. If I grease it well and put a boot on it I should be OK? Or should I just look for another shaft?
Ed
What, you gave it a circumcision? :eek:
What sleeve are you talking about, Ed? The rubber dust cover boot that our vintage trucks (pre 67) had (part 6)? It seems like the actual sleeve (part 5) that fits over the splines would be integral and not disposable. :confused:
Well it was worthless the way it was and just amounted to some very thin metal, so I doubt it was designed to do anything more than keep the grease in and crap out. I think I can come up with a shock boot or CV boot or something that will work.
Ed
BTW d/n know that the earlies had a rubber boot!
I cant seem to post pictures, that option is not available. WTF??
Here's the photo you emailed me. For clarification for other's comments.
It looks like a later DS, like I have on my FJ40. Had a metal sheath instead of a rubber boot. I don't suppose it is critical, but eventually the splines are going to get corroded/crudded up if they are exposed, which would interfere with the sliding capability. As much as you wheel that may not make a difference. :flipoff2:
I do happen to know of someone with a spare DS ;) . It needs to be retubed at a driveshaft shop, but the sheath is intact!
*Don't know why you can't do attachments. You musta forgotten to do service to Woody....:rolleyes:
Thanks for posting that pic. Doncha think a rubber accordion-style boot would work? Hell, for that matter I could weld on a new piece of tube for the dust shield.
Ed
A rubber boot is exactly what the old style had. In fact, SOR has some, used (#6 in the above picture) which would probably work fine if you can't find something locally.
I think Dave will post up a pic of what I'm trying. I had a shock boot laying around and used that. It was about like trying to put on a rubber one-handed.
Dave?.......
Was this on one that I gave you last week Ed?
Post up a pic of the bad spot...I do not remember those shafts having any issues....
In the past, if I have dented that piece that you are talking about....I have heated it up nice and red, and drove the shaft back into it...clearancing the piece that was in the way...it just pushes it back to where it will allow the other part of the shaft to fit again....not that big of a deal...
you should still not be needing to mess with this, if this was on one of them that I gave to you...
-Steve
Sorry, passed out from pain there for a while.....
Degnol's size 12 rubber....
As to whether it was one of yours', Steve, I don't know, but he has named the pictures "orion*" :frown: ;p
Thanks, Dave. Clamps on that biotch will be redundant, but I'll put 'em on there anyway. Other than possibly tearing it, does anyone see a problem?
Ed
Degnol Looks real good. My only concern may not be very important, but would the hose clamp be off balance enough to cause a balance problem on the shaft?
That little short thing? Probably not, but just to appease, I'll put them 180* opposite one another.
Ed
I'm just wondering if that rubber is stiff enough to hold shape when it gets to spinning, I know that boots are commonly used on custom shafts but they're usually short and pretty stiff, not sure but that looks kind of like a shock boot which is kind of soft. I'm thinkin it would become unbalanced and shift to one side and create a nice big vibration at RPMs.
Let us know how it all works out. Oh and don't forget the weep holes to let out moisture.
Big zip ties for clamps....
might work, loks like a rust breeding ground to me.
second look i kinda like the idea, my dodge has one like that one the front drive shaft.
Hawk, I noticed as I was putting it on that it has some weep holes in it. I'll have to see how it fits under normal compression/extension, but it should not be too baggy. And it IS a shock boot!
Ed
Ed
Cool,
Let's see the after pics when you get her all buttoned up. :D
Hawk, that was using what I had on hand, but I bet I can find a driveshaft/CV/shock boot that may be more appropriate. The one that is on there fits OK, but is, I think a little long. Problem is, if I shorten it, I won't have a flat sealing surface. I can always go back to option #2, which is welding another piece of steel tube on there.
Ed
you could cut it and then zip tie it. i dont think it would be a problem
That's a shock boot? Here, I thought it was a turkey gobble, like this. ;p
For $10 Marv will sell you the real cover boot.
