Driveshaft Question
Sorry if this is a quarter :banana: question but i'm in the process of adding front sway bar drops and a new used front driveshaft (until i can afford one of Slee's nice DC shafts). If i buy a used driveshaft, do i need to have it balanced locally? If i were to buy a new DS from Slee, does that need to be balanced too? Last but not least, how much does it usually cost to have a driveshaft balanced?
Thanks all for your cruiser wisdom!
With a 6" lift I would drive without the front shaft (CDL engaged) and wait for the dc shaft from Christo. They come balanced.
Where's the driveshaft that came with the truck?
The used driveshaft shouldn't technically need to be balanced, unless there's something wrong with it. If you were gonna run it permanently it might be a concern, and also changing the u-joints would be recommended. If it's temporary you can get away with it as is. Be ready for some vibrations and noise though. The vibes can't be good for the truck. Romer's got your best advice, if you must run the truck, run it without the front driveshaft.
-Spike
Thanks to the PO, the sway bar wasnt properly dropped (when lifted) so now the DS has a nice groove from hitting the sway bar. I posted a couple questions last week but if you havent seen it, here's the pic! :eek:
Gotcha. I remember the thread, but there's no way I can remember each forum member and their specific trouble. :D
-Spike
That's just a dust cover, you maybe able to order a new one or just take it off if it's only temporary.
Those look like stock arms, what CC are you running?
I agree on the dust cover comment...it may not even need any work since it is just a cover and not a structural component.
Tools, he has got nothing...it was a toss springs on lift job as I remember in the other thread.
The reason I asked about the CC is the driveshaft suggestions. The CC brings the pinion angle down, allowing proper geometry for the DC shaft to run smooth. Without CC it's still running broken back geometry with messed up angles, so ether type of shaft will probably vibrate. If your going to run less than ideal angles, it's going to be hard on u-joints. The DC joints are much more expensive and complicated to replace, maintain than the standard type. So I would run the stock type shaft until the CC is installed, then put on the proper shaft for the resulting geometry.
