You can steal the slip yoke end from the front shaft of an 80 series. A 40 has about 2 3/4 slip, a 60 has about 3 1/4, the front 80 has about 6".
Joint Fuji makes a kit with an 8" slip Cruiser Outfitters sells it. It comes with a the male and female slip, ujoints and the yoke.
The upside of the 80 yoke is that it allows 45 degrees of articulation vs 24~27 on 40 and 60 yokes. You will have to modify the
flange on the side where the 80 yoke will will bolt to. The bolt pattern is different. Cruiser Outfitters may also sell that. I just redrilled a pattern
for that this week. The transfer case had a round flange so, in that case, you rotate and redrill. All Land Cruiser driveshafts use the same diameter tube
so the slip yokes can be swapped between the different series , no special machining
We can absolutely supply pre-drilled tcase or pinion flange with the matching pattern.
Long Travel 8" Slip-Joint Drive Shaft Kit - Fits Early-Current Land Cruisers & Toyota's (UJ35050)
Cruiser Teq is the premier provider of high quality OEM, Japanese, and aftermarket Toyota Land Cruiser parts and accessories.
