Just want to make sure i'm not missing anything in my thought process. I just installed the Blackhawk heavy duty lower rear control arms that are 11mm longer than factoy. I am running OME heavy's front and back. I wanted bigger arms and had researched and felt that these would be perfect with the lift I'm running. I had no vibration before install of new arms but now have a vibration. It is pretty consistent from low to high speed when is torque is applied to driveline either on acceleration or on deacceleration . Vibration goes away when using feathering the gas to a neutral position or shifting to neutral.
My thoughts are that because of the extra 11 mm length which is designed to rotate the axle back down to compensate for the effect of the lift, it has rotated it to0 far and has the driveline out of the correct position. I am assuming i will need to add the adjustable uppers to properly fix this but want to make sure i not missing another cause.
Remember, no vibration before install
only change was control arms
vibration now.
I am waiting for better weather to get under it and check the angles.
vibration now.
