- Joined
- Jul 30, 2003
- Threads
- 75
- Messages
- 3,026
- Location
- Broomfield, Colorado
- Website
- www.gamiviti.com
Hmmm... so opposite of how mine is, eh? thanks, Rick. Can anyone else chime in and break the tie?
fj55-100 said:This is a age old concern that is now giting ugly . Fact - the noise/thump is caused by the splines on the slip sticking, when the shaft was made the tool left small scallops on the surface some seen some not ,and under load and braking causes it to bind, then when you GO it unloads and thumps--- the 120s are so bad that they have redesigned the shaft as a countermeasure to fix it ---- they changed the pitch of the teeth and have polished out all the rough spots .
as a short tearm fix we were instructed to remove the shaft and use valve lapping compound on the splines and work the slip in and out for a loooong time to try to polish out the high spots, then thourghley clean the slip and reassemble it using a HIGH pressure lube . So far it has worked well enough to hold off the shaft replacement untill it is off backorder,
I have experemented with the new slip by putting one in my 55 , its soa so it to thumped from time to time,, and after 6 months so far it has not returned--
I have a 120 as well it has not returned there either----
All the shafts that i have worked on i have put the date and repair (new or lap ) engraved on the shaft to do some long tearm studys for TMC ,
So we shall see in the future how they hold up
Hope the info helps............................
wrong post area, sorry.allen_ajones said:do it twice for good measure. Clunk will leave.
fj55-100 said:Rookie- the shaft itself on the 120s after production x240032069 has been updated Pn-37110-6a480 , that is the new spline vin start -
so far all the ones we lap in have been good -long term if you dont clean the compound out it will continue to wear while in opperation -- if its clean we see no lasting defects,----
has no bearing on the lifespan of slip or joints,
all the ones that were lucky to git a new shaft with the smooth splines are allready ahead of the game,
on my 55 i am experementing with the new slip ( it takes bolth sides so you have to cut the shaft and install the assy) or send to shop
ttfn
I have two thumps/clunks, both of which think are different.
I fixed or drastically reduced (90%) the first which ocurred after I had accelerated and then let off the gas, almost like the truck was ****ed that I didn't keep accerlating. I could lessen the clunk by not letting off the gasing but by just decelerating. That said to me automatic transmission fluid needs flushing. Well, it looked pink. But when I saw the old pink next to the new pink. Well, you could tell it needed come out. Well one of my clunks is gone. I will probably do one more tranny flush for good measure. But, just because the tranny fluid is pink doesn't mean it's good.
Now the clunk does not have "metal linkage clunk sound: but just a dull lower sounding thump. Still trying to figure what that is. I gues I gotta look for loose u-joint or unsecure rear drive shaft, etc.?
After learning the construction of the drive shafts here, would it not be good to grease to the max so the grease gets to the splines, THEN to remove the zerk and drive to let surplus grease escape?
