take the load off the diff, i.e. put a block behind the wheel, e brake off and in neutral, this will quarrenttee no friction to hold everything tight.
now crawl under and push the companion flange up and down, there should be NO movement, now turn the driveshaft by hand, you should only be able to move the driveshaft about 1/32 to 1/16th of a turn before it stops.
done
done
