Dripping condensation under glovebox
Just clean out the drain with compressed air and/or a small stiff wire. Have you replaced the cabin filters? Cleaning out that box will be all you need to do, if the drain cleaning doesn't fix it.
Look underneath for the drain hose and stick a coat hanger in it, then clean it as mentioned above. It's on the PS near the manifold. Can't miss it.
*edit* Don't poke in too deep to cause damage to the core.
If the housing is separated you can use a simply fabricated metal clamp to hold it together. Its a common 100 series issue. Mine used to drip and then stopped. But cleaning the drain and clamping down on the bottom of the housing should fix it. There used to be a fix thread for it with photos of the clamp job.
Try to get down and look under the dash at the evaporator housing and try to see if it is leaking from the seam. The easy, redneck fix is to take a dab of silicone or RTV sealer on your finger and smear along the housing seam, pressing it into the seam. I did that two years ago and no leak. Less than 5 minutes to complete. Yes, it's a half-baked fix, but it works.
Important to note the gasket has limited height, it only seals up to a certain point. If your drain is clogged and condensate reaches up above that level or you make a turn and it sloshes around, it could leak but have an intact gasket.
So step 1: remove cabin air filter and see if you can see debris and try and clean up (vacuum hose attachment?)
Step 2: unclog drain from below if housing is clear (otherwise it could easily clog again)
Step 3: inspect gasket if continues leaking
Anyone have a picture?
I took a few pictures while I was trying to clean the evap a few months ago, Usually the leak occurs at the bottom of the plastic cover.
There is a thread with lots of pics in the FAQ. You should read it too, @Bardiya , as you seem to not have the interior air filter slot either. My current (GCC) 100 did not have it. Easy fix and well worth it. UAE sand turns to cement in the evap when mixed with water, too me half a day to clean it out.
I read somewhere that a piece of weed eater line was a safer bet. Mine just started dripping as well (04LC), planning to try that first.
