Dreaded P0420
Montana
Long time creeper, first time to post a thread. A little history, I bought a 1995 FZJ80 with 165,000 miles. Purchased it knowing it had P0420, I got a pretty good deal hoping to be something other than the catalytic converters. Previous owner had both O2 sensors replaced so was sure that those couldn't be the problem,I did however checked the wiring to be sure there wasn't a problem, no they were good. So I did find an exhaust leak between the catalytic converters, sweet that has to be the problem..... Then.....
These two pics are the two mating areas between the cats. So I'm in need for some advise on new catalytic converters. Thanks
In advance.
I bought a single cat and had it welded in using the old flanges and stock O2 sensors about 3 years ago with zero issues. There was a thread with some part numbers for the cat. I ordered off online from Summitt Racing and had a exhaust shop weld it in. It was super easy and couldn't be happier with results.
Thanks for the quick replies. Profro, did the cat fit where the old ones did without moving the rest of the exhaust?
@jonheld recommended Discount Converters to me. I was going to gut mine or remove mine if I needed a new one. I ended up not needing a new catalytic converter (muffler shop pressure tested and it was excellent) but I ordered O2 sensors from them. They were great to work with. I take his word as the gospel when it comes to 80s.
I'm curious at what conditions you get the P0420 code. I get a code all the time and I just immediately clear it with the scangauge. I ONLY get the code when I'm driving about 40-45mph under a light engine load.. So usually on flat road. I can drive 4 hours on the interstate and never get the code. At my last job I had a 40 minute drive to work and I could almost tell you the exact spot everyday when it would throw a code.
My '95 has only one aftermarket cat and I haven't changed the rear O2 sensor yet as I just can't get it off.
What I've researched, if the second O2 sensor sees the same as the first O2 then the catalytic converter must not be working and that will through P0420. But there is a lot to check before you just replace your cats. I was going to fix an exhaust leak when I found the conditions of my cats.
Well I've been searching for a new exhaust, and doesn't seem to be much ot there for quality. OEM Toyota very expensive, discount converters seems affordable but not sure of quality. Then I've seen a lot of feedback of EMS performance, but seems to be long wait and then there is an issue with the flex coupling having issues, since it is hard mounted to the frame.
I'm guessing if @jonheld recommends Discount Converters for catalytic converters they must be pretty good quality. I have not heard much good feedback on EMS. If I was going to replace my exhaust right now I'd go with Discount Converters for the cat and have the shop fabricate everything else out of stainless and use rubber hangers. The issue with EMS is the flex coupling because the rest of the exhaust is welded to the frame. Thus when motor is vibrating there has to be something to absorb the flex.
