Drain locations pics
Missouri
Hey guys, need some help. A couple months ago I started having soaked ps front carpet, after rain events. So mud came back with a few probable issues.
I am trying to make sure I cover all bases, so my question how many drains are there in the rocker location? Also where exactly does the cowl between the windsheild and hood drain? Pics are super helpful, thanks
^X2
Yes I agree with the sunroof being on the list of likely culprits. But doesnt it drain into the rocker panel?
yes, but the rocker full of water will not make the carpet wet.
the roof drains blocked will.
the rocker not draining just makes a sloshing sound.
Ok, I thought maybe it had a way of backing up into the floorboard. The other day I ran string trimmer line down the drain, for a considerable distance. But I couldnt find where, either I ran far enough out of the drain tube to be hitting the rocker or where I hit the obstruction. It may be easier to clear it towards the bottom of the drain tube. Is the end of the drain tube accessible around the kick panel? Also where does the water from the hood cowl drain? Thanks
I'm pretty sure you know this already, but the windshield has a common leak on the inside in the bottom corners. I had that problem and had to have the windshield replaced to fix the leak. Thanks to a gravel truck I got it replaced for free.
X2 on the windshield. Mine is aftermarket install by PO and if it sits outside in the rain for multiple days my carpets starts to get soaked
Had a windsheild repair guy do a type of air test on my rig. It was a bad windsheild gasket. Pulled the windsheild and replaced the seal, rain today so we shall see if it works. Thanks as usual.
Had alot of rain a couple of days ago, leakage again. Although for the amount of rain, not as much water inside the cab as there would have been prior to windsheild gasket replacement. Its back at the shop today, so we shall see what they come back with. Certainly a possibility of more than one leak.
