Effin' awesome man!! What do you put the odds at for having it done by CCLR?
Friggen outstanding, well done Ramon...![]()
RThanks Jerry! Hey, wanted to see if you had any extra of that 2" tubing we used for the main rails on my seat cradle? Need about 1 ft, so hoping you have some scrap left. Also was going to try and hit you up to cut 2 notches if you wouldn't mind... your notching setup is so dope!
R
Nice!!
Ramon
RamonDont waste your time with opening that motor up at all. Just put it in the 40 and party. I wouldn't bother with running it on a stand either that sounds like a pretty big waste of time
@GLTHFJ60 sent me here to be your LS advisor
Ramonthose broken exhaust manifold bolts are actually super easy. I deal with them all the time. Even the ones that are broken off deep. They come out easy, they aren't seized in the head, it's the old bolts that're weak. Just take your mig welder and start building up tacks on it. You wont really hurt the aluminum threads. It doesn't hurt to run a tap through it after though.
As for the oil pump, timing chain stuff like that , those all last the lifetime of the motor, 300-350k
I would highly recommend the Sloppy Mechanics Youtube channel, he has a TON of videos with LS tech info including a lot of Holley tuning advice. If you are leaving the motor stock you won't have much tuning to do if any but still great info.
