I have them and absolutely hate them out of the box. It felt like the axles were bolted to the frame on city streets. My FJ40 does not have a hard top or rear seats, but it does have the hard doors installed, 8k lb warn winch, 32" tires. After numerous tries I ended up with this combination:
Front:
installed the 2nd shortest leafs from the rear pack (more arch)
removed the shortest Downer leaf
installed the shortest stock leaf
Black diamond shocks
still needs longer shackles to even out the ride height.
Rear:
removed the 2nd longest leaf (put it in the front, throw the front ones away, or use them as add-a-leafs, they look identical)
Installed the 2nd longest stock leaf
Kept the shortest Downer leaf
Cheapest Monroe shocks available ($17 for a Ford truck, I had to remove the bushings and use shackle bushings instead) They have even less compression dampening than the Black Diamonds.
Longer shackles to restore some of the lost lift from removing the 2nd Downer leaf. Shackle angle is normal now.
I used late model ubolt plates so I could use longer shocks and because the arch of the springs made it hard to intall the shocks unless the spring were compressed.
I just took it through Rubicon last weekend and it seemed to flex fine, the rear shocks look like they were compressing around 5" and the fronts around 7". With my new power steering and Australian 4 speed/3 speed xfer I don't know how I ever did it before.
IMHO,after the mods, they are OK for light rock crawling (no military raps) but still suck on the the road (I still have 150 lbs of sand in the back).
