I like NLXtacy's story better.
You should really add a Poll.
Hey Joey, let's go to Gorman and do some hill climbing with your LX470.
get familiar with the lineage
Randy....did you vote for yourself?![]()
The number is C414303 which means it was made in 2003? So 6 years old and that's that.
Are 4303 the last digits or is 303 the last digits? It makes a 20 year difference! 6 year old tires are NOT old tires. I'm running on tires produced in the '80's on both the '55 and the '60 though the tires are due in for replacement on the '60 this year due to wear. The tires on the '55 still have alot of tread so they should be good for a few years yet. It's mostly relatively low speed and poor roads here in Guatemala anyways.
All this talk of old tires is making me think about taking two spares as I have 6 old 32" tires for the '60. I don't want any problems as I drive north from Guatemala on these old tires.
Looks like Randy bribed a friend!
Funny how neither version mentioned that Randy called me first.![]()
The way I learned it is if the tire is older than 6-7 years dump it. It doesn't matter how much tread it has on it. It could have sat on the shelf its whole life and appear brand new. Rubber degrades over time and therefore I am not going to risk my life on 6-7 year old tires.
I had a similar blow out on "pre-owned" tires that I had on my 60 and I am NEVER going down that road again. HTH.
It's the Hawaiian style pot holes the size of a Geo, Chuck. Those swallow cars whole and spit out rust at the other end. Gotta watch out for those buggahs.
EDIT: Or is it the Civil Service patch jobs done with needles and spikes in tar?
By the way, bet the GF was impressed with an adventure like that!You forgot:
5. Get a 60
The 62 thing is part of the problem. I think Cliff (the guy from the bar?) said the 62 weighs more than the 60 and was set up for far greater speed, thus the camber is not adjusted correctly on the 62 for local driving leading to excessive tire wear, and if the brake blowers are not working, the 62 is prone to bead failure on high speed interstate runs. These problems plague only the 62, not the 60.![]()
Actually Randy didn't mention that he called you first. That cheating bitch![]()
????if the brake blowers are not working, the 62 is prone to bead failure on high speed interstate runs.???
What are brake blowers and where are they found?
