Does this seem real?
Ok. My Mechanic (im assuming hes pissed for me calling his bluff) but hes now telling my my driveshaft is twisted. As in like if you take a stick and twist both ends opposite directions and the stick splinters in the middle. Well I think thats utter and complete bull****. I was under the truck trying to do the repair myself and saw no bent driveshaft. Im speaking about the front one by the way. How common is this occurance?
well, that's not so easy to fake, unless he's *really* pissed at you, is pretty strong, and has some big crowbars.... :D
Never heard of that, seems like it would make the truck vibrate like crazy on the drive to his shop. Go look at it, bring a camera.
-Spike
Not easy to fake but very easy to fake to my dad who is a car retard and will say oh ok, well replace it then.
-Spike
Yup thats what I said too. And I had very little to no vibe at all more than likely caused by the loose u joints themselves. I drove it on the interstate at 65+ for over an hour 2 days before it went in the shop. How did It bend between now and then and not have a driveline vibe?
I wonder if he's saying the u-joints don't line up in the same configuration as the rear driveshaft's u-joints? If so, they're not supposed to. Maybe he thinks someone serviced the driveshaft wrong, or is he saying you need a new one?
-Spike
He is saying I need a new front driveshaft because it was like, well imagive giving someone and Indian sunburn. Its like that it was twisted like the metal driveshaft itself was twisted around. This guy is a liar. Never use Brian Massey Imports.
I was gonna say, unless the driveshaft tube itself looks like a twisted doughnut it ain't twisted! Didn't you have other problems with mechanics recently?
I have seen many twisted driveshafts. We used to paint a stripe to see where they would twist. Never on a Toyota though. What was it taken to the mechanic for and why would he assume it was twisted?
I'd go there and give him the benefit of the doubt. Ask him to show you the twist, and be ready to be amazed. Maybe he's right. As mentioned before, that would be hard to fake, and he'd look pretty bad if caught replacing good parts, especially something so easy to see. Listen to what he has to say before you write him off. IIRC your dad is the one who likes him, so the choice of mechanic isn't all up to you. Make absolutely sure you're right before getting into a pissing contest with the guy.
-Spike
Carter, if you need me to take a look at it, I will be glad to. The likely hood of it being bent is very slim, especially since it is a hi-pinion design. You still have my #, right?:cheers:
I'll bite. He thinks because the 'ears' on the front drive shaft's forward end are 90 degrees out of phase with the 'ears' on the rear end that the shaft has been twisted.
In that case he's a moron for two reasons. To wit:
1 - When you twist a HOLLOW drive shaft it caves in and is painfully obvious. Yours isn't. If he doesn't know enough about mechanical things to be aware of this, then he's questionable at best in mechanical skill. Sorta like twisting a beer can - it caves in as part of the twisting.
2 - The front shaft on an 80 series is SUPPOSED to be 90 degrees out of phase. Guess he's been servicing Pop's truck with no factory info then??
I rest my case.
DougM
wow. I hate Memphis mechanics. I just had my 62 at Brian Massey yesterday, it was an utter disaster. Couldn't fix my problem, told me to take it to Performance Tire off of Covington Pike (never go there). Supposedly they rotated and balanced the tires and aligned the truck. Got home with a flat tire and a busted left knuckle seal. Took the tire in this morning to a tire shop to get it patched. Turns out Performance Tire had gotten a flat tire while they were test driving it and tried to cover it up by doing a s***ty patch job that lasted less than 15 minutes and somehow screwed up my left knuckle which has a serious leak now (knuckle grease all over the tire and ground) when before it had been pristine before. The owner of Performance Tire was a complete dick about the whole thing too and pleaded innocent to the flat tire, until i rolled the tire myself back into his shop and made him ask one of his mechanics if it was their patch. Sure enough it was. Still dealing with the knuckle issue.
