Does my LX stink?
Knoxville
I get a pretty potent exhaust smell from my LX. My wife has commented on it often (she has a sensitive sniffer). If I start it up in the garage, or if I stand behind her when she idiols, I get a pretty heavy exhaust smell. She runs great, but do you all notice the same with your rigs?
Mine does exactly the same
The only thing I smell is the oil that leaks out of every 23 year old seal...
96 LX smells the same.
Ya Its called carbon monoxide when you start your truck in your garage and cannot exit all that fume out of your garage.
CO is odorless. The smell is most likely unburned gasoline, or possibly hydrogen sulfide, and our truck reeks of it like unholy hell as well. We figured we had an exhaust leak, though this indicates that this may be normal operation. It's bad enough that we don't like to sit in the truck as it idles.
On cold start the truck runs very rich likely close to 11:1. If you go out and run errands the truck will settle into closed loop, and I bet if it was at operating temp and you did the same garage test you would see a big reduction in odor. It is possible that you have a bad O2 sensor, etc that is making you run rich all the time, but a warmed up truck idling within the narrow band O2 sensor parameters shouldn't stink.
Same here on cold start. If it's a really potent rotten egg smell, you could try a different gas station, maybe the gas you're using is high in hydrogen sulfide.
Use a rag to protect your hand and hold it over the end of the exhaust pipe to block it off when the truck is idling. You'll be able to hear an exhaust leak as a high pitched hissing sound. Mine was between the cats...
