So I installed the 45mm Dobinsons springs and with 31s the front is 36” and the rear is 35” from the floor to the bottom of the fender opening.
Did you install stock shackles or lift shackles?
Are Alcans that much superior? I was quoted right around $650 for just the rear leaf springs from them. Opinions appreciated![]()
Are you running stock length shackles and how do you like the ride? Thanks again.So I installed the 45mm Dobinsons springs and with 31s the front is 36” and the rear is 35” from the floor to the bottom of the fender opening.
Also how is the stance of the vehicle, could you post up a pic? Maybe @crikeymike may chime in as well. Thanks.Are you running stock length shackles and how do you like the ride? Thanks again.
Yes, I installed stock size shackles.Did you install stock shackles or lift shackles?
I've been reading along. Do you have a question for me? Seemed like more of a comparative discussion so far. The info on the Alcans is good to know.Also how is the stance of the vehicle, could you post up a pic? Maybe @crikeymike may chime in as well. Thanks.
Hey how are you? I do have a question, can I still use my 0-2” lift compatible Bilsteins if I go the Dobinsons route. Says their springs are a 45mm or 1.75” lift for us Yanks. ThanksI've been reading along. Do you have a question for me? Seemed like more of a comparative discussion so far. The info on the Alcans is good to know.
Good thanks!!Hey how are you? I do have a question, can I still use my 0-2” lift compatible Bilsteins if I go the Dobinsons route. Says their springs are a 45mm or 1.75” lift for us Yanks. Thanks![]()
I am running the same shocks and 31 tires as well.0 - 2” Bilsteins on mine with the 45mm Dobinsons and 31” tires.
How do you like the ride with your setup?Here’s a picture.View attachment 2582537
March 1976 build date. Nice to hearMy original springs were tired. The ride and flex is way better. Is yours a 75?
Considering the springs you have installed. With your amount of lift, 45mm or approx 1.75” is it possible to run 33” tires? I am running 31’s presently and will probably stay with that size but just curious. Also how do you like the ride quality of the 45mm leaf springs. Thanks.So I installed the 45mm Dobinsons springs and with 31s the front is 36” and the rear is 35” from the floor to the bottom of the fender opening.
I like the “forklift” reference. I had mixed results with the re-arch. I also do feel the old springs are tired and time for some new ones. I wanted to keep stock ride height, but the Dobinsons are the closest to stock height without going the spendy route with Alcans. As I have much to do on the ‘76 and will be posting a build thread as well in the future I am going to go the Dobinsons route. Any chance you may have part numbers for what you put on yours? I am looking for stock load springs for best ride possible. Thanks againI’d say no problem running 33’s. I think the ride quality is much improved, no longer like a damn forklift.
