Do I need this
Misssoula
I have a 74 FJ40 and part of this stupid-plastic-vent-thingy is broken. Can I just toss it or does it serve a vital purpose? (My cruiser is smog exempt.)
Thanks.
Yeah, throw that out and you lose the Star-drive! :eek:
That's the flux capacitor, it's not needed for sub-lightspeed travel.
Eh, a broken flux capacitor in good condition is rated at 0.3 Ludacris Speed, so I think you're good to go. Just don't pull the Emergency Brake at full throttle, it'll hurt ;)
in my opinion you should keep it and hook it up as it should of been used oem. This way you won't have issues with fumes inside the vehicle when you go up and down in elevation and with temp changes. That fuel seperator allows vented air to go to your charcoal canister and then be used by your engine to be burned. Mine was not properly hooked up and I had venting gas tank issues, and yes I have a vented cap. Usually the little white fuel filter looking things (one way check valves) go bad. I have had good success replacing this check valve with a piece of metal fuel line and no problems so far.
Noah
