I have a Summit racing external fuel pump that will be used to transfer fuel from my aux tank to the main tank. The pump will be run for 15-30 min at a time. it is listed as drawing 4A max. The switch I have is listed at 25A. Can I just run power straight through the switch or do I need a relay? If I don't need a relay should I switch the + or the -?
Sounds like you'd be safe. But as something connected to fuel, i'd agree with @amgraham and run a relay. I always run relays just for the protection factor.
I would do a relay so that in the event of a short in the switch, it can still be unplugged or disconnected.
You can switch either the + or the -. Toyota always switches the - side.
I personally prefer to switch the + side so that if there is a failure, it fails as non-operational (NO normally open) rather than operational (NC normally closed)
No need for a relay. Like you mentioned, draw is 4A, switch rated to 25... plenty of safety factor there. definitely use a fuse though. 5A should do the trick.
whether you open the + or - makes no difference.
Been running my aux tank system straight off a fused switched for almost a year now with no issues!
