So, here are a couple of interesting distributor units. One has been described as a, "paper weight." The pins on the governor shaft for the centrifugal weights have been ground down by abrasive. Either too much New Mexico (there is a hole on the underside of the aluminum housing), or rust from crankcase blow-by and/or ozone from the points (had igniter deleted when I found it).
The other unit looks not far off from that. However, there is still a tiny bit of bushing on the weights, and centrifugal advance governor pin. So, this one is getting cleaned up, as it deserves not to be forgotten, even though there are better distributors out there there. It is the original distributor for my April '75 motor; and, I've seen quite a few Mudders running original equipment. Let's just say that curiosity got the best of me, and it is dark out, so now is a good moment to spend time in the lab.
Anyone, have a lead to find new bushings for the centrifugal weights, and cam governor pin? Which is the part number? 19100-61020 or 029100-3160?
Also, anyone have good documentation about the centrifugal advance curve on this and other available distributors? I believe that the one currently installed is 19100-61080-Non USA vacuum advance?
