Here’s a 150... it’s $500 less, but further away. Do you have any friends in Kelowna?Somehow I missed that above. Thanks very much, will look into it!
The 251 was even setup for a spool gun.
NVM, based on google it seems to be overpriced and light for aluminum... and not suitable for a spool gun.Here’s a 150... it’s $500 less, but further away. Do you have any friends in Kelowna?
If I had the choice I’d use TIG... that way I’d get paid to practice. Welding seems to be about 10% theory and 90% practice. There’s only so much someone can explain... the rest is feeling / instinct.
Not mentioned was the fact that the argon bottle has been empty for 2 years. I'm the only guy who gives a s*** and wants it filled, but I can't leave the building to do it when I'm on days, so stick it remains.![]()
When I said I gave a s***, I may have exaggerated slightly...Can you spend some precious public funds and get gas delivered? Anything to make the work day more entertaining.![]()
Those little stick machines are pretty cool and very useful. We use one like the Miller @seapotato posted for the smaller stuff but they burn pretty hot and can me wired 110 or 220.
Easier moving that around then stringing welding cables all over the machine, let alone up and down this f***in stairmaster all day.
When I said I gave a s***, I may have exaggerated slightly...![]()
Sorta wish I'd gone for the 212 , I have @Toshi38 's in my shop. Nice machine.
Haha, I haven't used it much actually. With the thick wire in your machine, and the thin stuff in mine, I was thinking swapping bottles would be easier than swapping wire, but then, I'm still too lazy for that, so I've mostly just cranked mine up and zapped the piss out of whatever thicker bits I needed to weld.Ya I was very happy with that machine... The advice I got was to spend as much as I was comfortable with that I wouldn't regret having a little bigger machine and I stand by that now... Even if it's just for seapotato to use
Thanks but it pretty much never comes up. I thought about buying one years ago, but I wouldn't use it enough.Should you need plasma cutting, I have a Hypertherm . It will easily slice 1/2”. Like butter.
Tried your plasma cutter a couple times but couldn't get it to work... so that's not getting much use either
I want to make a scissor lift table/work bench, so I might have another go with your stuff once I get motivated enough to start on that, but it might end up mostly wood and not steel anyways.
