DIY Rear Upper Control Arm Adjuster
San Jose
Has anyone done the do it yourself adjuster for the upper control arms? I would like to do it but I'm not ready to spend the 230 slee is selling to do this (link attached). Slee takes the guess work out of everything but it's not in my budget at the moment. So has anyone done this using other weld in tube inserts, bungs?
-Juan
Slee - Toyota 80 Land Cruiser Series Suspension DIY Pieces
I had some made by a local machine shop in a small group buy for some local cruiser guys including myself. They are different from the Slee ones in that they are beefier. They truly look pretty massive. We did these over a year ago and mine are still sitting on the shelf waiting to be installed. We basically came out on these around $130 for a pair of adjusters. He made us some panhard adjusters as well for about the same cost so we ended up at $260 for all 4 adjusters. Here some pics.
I think if you find a decent machine shop in your area you should be able to get some made to whatever specs you want. I'm not sure quite how these compare to the Slee ones since I haven't seen the Slee ones in person, but they are definitely larger diameter (except for the the bungs that weld into the stock arms).
all 4 adjusters
rear upper control arm adjusters
panhard adjusters
all 4 adjusters
panhard adjusters
Where did you find those adjusters, those look great!
-Juan
-Juan
Did you read my post? I explained where I "found" them. They are from the future.
I just want to do whatever it takes to get rid of the decel growl
For me, the decel growl was coming from the front DS. I replaced that with a DC shaft from Slee and no more growl. I still have some DS vibes from the rear but that is because I haven't installed those adjusters yet to correct the ujoint angles.
I have the DC shaft but I'm still getting the growl from the rear ds.
I guess I'll wait till I can pony up some money to get the slee's.
Thanks all,
-Juan
I just want to do whatever it takes to get rid of the decel growl!
I put a set of Slee springs on a 91 80 and the owner asked that we put on some MAF spacers as well. So that is basically a 5" lift and he called to let me know he had a rear vibration on the highway.
Seemed similar to what others have reported on here with some of their lifts.
It turned out that he had a bad pinion bearing. Not so bad that you could feel some slop in it just worn enough to give him problems.
Here are a few picks of the pinion and bearing race.
It is really not that hard to check for this.
Drop the drive shaft and remove the flange nut from the diff flange.
Remove the flange and tap on the end of the pinion.
A good bearing will be such a tight fit the the pinion will remain in place. In the case of this pinion and my son's (checked it today) very little force caused the pinion to move in the bearing and become very loose in the diff.
Upon inspection the race of the bearing has a slight taper to it and was the reason for the vibration.
Now installing joints to alter the pinion angle would have probably reduced or even eliminated the vib but that would only be a temporary solution and with time ithe bearing would fail completely.
Just a word of caution on what Rick recommended. You can not just do that and not know how to put it back together and insure that you still have proper pre-load on your pinion bearings.
Rick, did you check the pre-load before you took that apart?
Unless that bearing was that worn that you can feel the slop I doubt that it could cause a driveline vibration.
If you put the nut back on so the stake mark lines up where it started it will be fine.
Doubt all you want Christo the vibration is gone.
Rick, so did you guys rebuild the whole diff? Just the bearing? Or how did you fix it?
From the looks of it, that bearing spun on the pinion. The fit of that bearing on the race is a machined fit. In most all cases if you take the nut of you will be able to tap the pinion on it's end and it will move.
Also, not measuring the preload before (which is not really possible unless you pull the axle shafts) one can not rely on setting the nut back to the staked position.
we replace the diff with a good one we had laying around.
I think what rick was saying if the diff was screwed up the way it was it would have to be taken out and rebuilt but if you were to pull the nut and flange off and the pinion was ok you could just reinstall the nut and re-stake it in its original place...the same way you would if you were just replacing the pinion seal
