distributor o-ring and timing
north carolina
Did my O-ring today. I marked things so I knew where they would go back and took pics etc.
Pulled the cap off and there was the tiniest bit of oil in it. When I took the distributor out it looked like some oil poured out of it so maybe the seal inside is shot to but that's a story for another day.
My plan was to just throw in the 0 ring and do the tune up later as I was pressed for time. At any rate I dropped a bolt for the cap somewhere in the engine bay. So Not having time to do plugs and wires I threw on the new cap and rotor.
So I think I got the rotor in the right spot.
So I start the truck up. It starts right away and is running pretty rough. Check engine light starts flashing so I shut it down.
Then I realize I am off on my 12 mm adjustment bolt. I set that.
Fire it up and its a bit better.
Then I realize I had 2 plug wires in the wrong spot.
Fire it up. Check engine stays on but is no longer flashing. The idle is maybe 50-100 higher then before but the throttle seems to have more snap as well. Truck ran real good for 10 minutes and I was getting on it pretty hard.
I assume the light came on for the 2 issues I posted above but can it also stay on if the timing is off.
Can it just be running better because of the cap and rotor? I have no idea how old the cap and rotor were or the spark plug for that matter. The wires are aftermarket PERFORMANCE Sti wires lol. I have oem on the shelf waiting to go on.
Long story short it idles smooth and pulls same/better should I leave it alone until I do plugs and wires in the summer.
I'd check the timing and if ever thing is good, leave it alone until the summer. You don't want to be advanced or retarded excessively on the timing.
would be to advanced or retarded show up in my mpg and performance. how far off is too of without really being able to notice while driving
I learned this thru experience:
Remove spark plug wires individually off old distributor and put wire on new distributor.
DO NOT REMOVE all wires at once Like I did. Don't forget the dielectric.
Aren't there numbers printed on the wires and numbers on the cap?
Only if you get the Yazaki (OEM) wires.
I couldn't see paying over $100 for set of wires so I went Japanese made NGK.
They have been satisfactory.
I just did this to my truck this weekend. I followed the advice of one wire at a time when switching over the wires. When replacing the seal, I also marked my distributor to get the rotor placed correctly when reinstalling.
Get a timing light and set your timing per the fsm. Use a sst (wire) to jump the TE1 terminal to the E1 terminal. Check timing with the timing light. Adjust the distributor until you get the timing where you want. You do not want to run around with the timing off, you can damage your engine.
I messed around a little bit with advancing the timing as some have done successfully, but was getting a bit of pinging off the line at low rpms. I backed it off to about 4 degrees BTDC. FSM calls for 3 degrees BTDC.
My rotor and cap were pretty worn, truck runs smoother, and feels like it has better jump off the line, and just smoother through the rpm range.
Do you adjust the timing with the enigne running (I know you have to take the timing readings w/ the engine running), or do you get the timing reading, shut off motor, move dizzy, then repeat the reading process? I've always wondered how that worked...
Can be done with it running.. just have the distributor bolt BARELY loose enough to turn it and get it in range. A fresh o-ring will provide some friction to keep it from flopping all over the place.
Why do I need to jump terminals
...to stop the ECU from dynamically adjusting the timing. If you don't jumper TE1-E1 you will never successfully adjust the timing correctly since the ECU is continuously varying it.
cheers,
george.
So I read to test the truck without the terminals being jumped and I think the reading was 15? Then when I tried jumping the terminals nothing would change. I uses paper clips etc and no change at all.
Warm the car up. Make sure your timing light is on the first plug wire. With the vehicle off, insert the jumper. Start the car, aim the light at the crank pulley, you should now have a good reading. Adjust per above with the distributor just loose enough to turn while the engine is running. If you are reading 15, you need to back it off significantly. Fsm adjustment is 3 degrees btdc. If you can't get it lower than 15,maybe your distributor is off a tooth? Did you pull it and replace the seal? The rotor will turn when you pull it out and again when you put it back in making it easy to be off a tooth. I don't know if being off a tooth will get you 15 or so as I got mine back in correctly the first time.
How would I know if I skipped a tooth? Also is it is supposed to be 3 and I am really at 15 wouldn't there be a noticeable drivability issue.
I drove the car 20 minutes. Checked the timing using the first plug wire. Shut off the car. Jumped the terminals and got the same result.
Passed. Owned that I didn't set crank to 0. Maybe previous owner did it wrong and I just put it back to where he had it.
Could it be running normal that far off?
With the crank shaft pulley timing mark set at 0 degrees, the dizzy rotor should be pointed at the #1 wire on the cap (approximately 1-2 o'clock). If it's in any other position the dizzy was installed incorrectly into the head. If the dizzy rotor is pointing between 6-7 o'clock (180 degrees out) the engine needs to be rotated until the rotor points between 1-2 o'clock, with the crank pulley lining up on 0 degrees. Once the dizzy is correctly installed into the head you can then adjust the timing with the engine running using the procedures already presented.
I've never thought about that and have never been ask that. I don't see how it could run great with the timing 180 degrees out. I installed the plug wires clockwise instead of counter clockwise on a 302 V8 Ford distributor cap once and it ran, but it ran terrible. I believe you would run into something similar if the dizzy was installed 180 out.
