Picture this (hypothetically speaking):
ON A 1992 LAND CRUISER WITH THE 3FE, YES 3FE ENGINE!
You pull out the distributor and turn it over a few times with the starter. When you reinstall the distributor, you do NOT follow the FSM! Also, you modify the distributor so you can turn it 360 degrees (with bolt out of course, but holding it down by hand).
You crank it with the starter while turning the distributor until it starts. Then stop the engine, pull #1 plug, check pressure (blows out with rotor pointing toward back left) so you know your near TDC (not out 180 degrees). Start it back up, warm it up, short the diagnostic, and time it per FSM (on the 7 BTDC mark).
Question: Does it matter?
In other words:
The axle of the distributor has a gear tied to a gear on the cam, cam is tied to the gear on the crank, crank is tied to the flywheel with timing marks. All of this is geared together so "dumb", RIGHT? Every 2 revolutions by the crank the cam revolves 1 time & hits TDC once. Does it matter the position of the distributor as long as you turn it to where it "thinks" it's at TDC at the right time?
The axle of the distributor talks to the ECU via pick-ups in the distributor. This is the "smart" part which sends spark at the right time to the plugs/combustion chamber/cylinders.
I think that it doesn't care if the distributor is in the correct location with bolt in like normal, or if the "adjustment gap" is 40 degrees off and held down by hand. Am I thinking right?
Please help me resolve an argument between myself and a buddy at work (both shade-tree mechanics).
Thanks,
Joe
In other words:
Thanks,
Joe
), I've put that distributor in many, many times! I may be an idiot, but I'm telling you it ain't goin' in right!
