Distributor help
San Diego, CA
I went to install my pertronix kit and one of the small washers used to hold the pickup sensor fell into the distributor.
  1. I put the rotor back on and marked it's position on the side of the distributor housing.
  2. I pulled the distributor out and got all the FOD out of it.
  3. I aligned the oil pump shaft as best I could with a screwdriver
  4. after a few attempts of re-aligning the rotor and moving the oil pump shaft, the distributor easily slid all the way in to its seat.
  5. I just got everything buttoned back up. The rotor was back at it's original position
I've read all the warnings that it's possible to put the distributor back in but miss the oil pump shaft. On the attempts I got wrong it looked like the distributor wouldn't seat and was about 1/8" off of the boss on the block. Last attempt it went all the way in. Is there anyway I can know it's seated, or do I have wait until I fire the engine (that will be awhile)?
This is on a stock 1F it that makes any difference.
I measured the distance from the lip to the bottom of the shaft (to the bottom of the slot), then translated that to the distributor shaft so I knew when it was fully seated.
Ray, If you have an 1/8” or less between the last machined surface of your distributor housing and the top of your clamp, you are in. If you have a 1/4”, you are not.
if your gauge is working, you will know within 3 seconds of start up, long before any damage is done.
Awesome, thanks for both replies
You’re welcome Ray. Remind me of the ETA on your carb again. I’ve got five people on the ETA list, and you are not one of them.
I was packing it up and found some more gas in it. I was giving it a few more days to air out. I should have it in the mail Thursday or Friday of this coming week
