- Thread starter
- #821
Yes, first the brackets get bolted to the frame, then you will bolt the grill guard/stinger to the center section. ( this will make an easy spot to grab ahold when installing the center. ) once you slide the center section into place there are 2 allen head bolts per side. These bolts will align the center section on the brackets. Once those are installed the wings can be installed. The wings will lift into place and the slide over the head of the alignment bolts. Then insert the 2 bolts through the grill guard plate into the wings, this will hold the wings in place while the caps are installed, install the caps and tighten all bolts.Ben you have any detail on how the modular setup will bolt together yet?
I know it sounds complicated but it really isn't, once the brackets are installed it only should take about a 1/2 hour to install the winch and assemble the bumper.
