Some aluminum slider progress!
We will also offer steel but I think the aluminum will be a great option for most.
Perhaps it’s a aluminum hybrid style? Top section aluminum and the bottom contact area steel?
Yes, these will be intended as a slider and designed to take the full weigh of the vehicle.Are those intended to withstand full impacts i.e. literally sliding over or against rocks?
I ask because it looks like the main slider length is split in two pieces in the middle...right where the full impact of both axle loads would impact at the seam. I've never seen a slider design that has a seam in the middle like that.
Am I see that correctly? (circled below)
I’ll get better pics of how everything ties together as we get closer. It will be extremely strong I believe but we will also be testing them.I was just guessing. I am sure benc will be able to answer the specifics. Maybe the top part is two piece like a shell and the bottoms part is one piece? I dig it...it almost look like factory steps but with slider function.
Correct.Ahhhh.
So the seam isn’t bearing the weight...as much as an internal piece of some kind....meaning the aluminum shown is more an outer shell not fully responsible for strength...
I have a 14 getting bumpers now but still need to get ahold of a 08-12 for test fit before I can sell them. I don’t believe there would be any issues but have to check.Have an 08, interested in a rear pending price, etc. Anymore shots of the roof rack? How much higher does it sit than stock bars?
Will you be required to drill holes in the frame for the sliders? Or will this use existing holes? As a guy with limited knowledge and skills I'm hoping these will be relatively easy to install. Definitely interested light weight options.
There will be some holes that need enlarged for m8 rivnuts but other than that should be pretty simple.
Wish I were closer to you, as I have a 2010 that would look great with your bumpers!I have a 14 getting bumpers now but still need to get ahold of a 08-12 for test fit before I can sell them. I don’t believe there would be any issues but have to check.
The roof rack sets about the same height as the factory bars, maybe even a little lower.
