[dis]courtesy light troubles
Sandy Utah area
So my passenger rear door doesn't trip the courtesy light for some reason. this is annoying since the car will lock itself after a given time if you haven't opened a door. Since I often open that door first to put my daughter in...long story short you don't want to be looking at your daughter from outside a locked and closed truck with the keys in it. Anyway, I replaced the switch assuming it had just gone bad...nothing. I tracked the wire but It wasn't clear where it went and it doesn't go right to the dome light assy as I had hoped but meets a junction someplace else. The wiring diagrams weren't a ton of help because:
a. I don't diagram read good
b. they don't tell me WHERE the junction is.
Anyone have any suggestions to where I can look for diagnosis?
The overhead light or the one in the door?
Did you replace the switch in the door jam? Its just a single wire that goes into the pillar from the button which runs into the body harness.
Never found the short in mine. Same issue. I spliced in a new wire from the switch to the front passenger kick panel and this solved the problem for me. Now if I could just figure out why the front dome light isn't getting power... (Not related.)
Both my rear door switches had worn out, easy quick replace, might have been about $7 a piece.
IS the splice just under the kickplate on the passenger side rear door?
I thought someone found a splice that went bad and had a problem like yours. Was it under the passenger seat or maybe inside the passenger door jamb? Hopefully someone chimes in that remembers.
Thanks, I will take a look at this when I get back on Monday, Much obliged.
Having this issue on my 99LC, driver front door. I replaced the switch new switch did not work. I tried new switch in other doors switch is fine. I tried switches from other doors in front door, did not turn on dome lights and did not turn off automatic headlights. I opened up the side panel and checked the wire, but did not find a splice in the kick plate. I did find a patch in the wire were someone, maybe the entertainment installers or the alarm installers may have attached a wire. But i didn't find a wire attached, so i cut the door wire and soldered it back together, then i took some sand paper and cleaned the metal part of the switch that contacts the body of the truck. Still no luck.
