Carburetor doesn't look stock.
To better understand how and why some of these things work.... Take the air cleaner off and have someone sit inside the truck and push down on the gas pedal, and look what happens inside the carb (with the engine off). You should see a small amount of gas squirted into the barrel of the carburetor by the accelerator pump, and you should be able to find where the throttle linkage hooks into the plunger that pumps that fuel into the barrel.
This squirt of fuel is adding gas to help it start. Too much can prevent it from properly vaporizing, I guess, somehow (never really understood that part myself, just know through experience it can happen).
Have them pull on the choke cable. You should see a plate inside the throat of the carburetor close, restricting the flow of air through the carburetor. This forces the air to speed up and be more turbulent as it goes though the barrel of the carburetor, and thus evaporator more fuel into the air. Because you don't have a stock carburetor, check if there is a choke on it, and that it's closing when the cable is pulled. (I don't have a stock carb, and don't have the choke cable connected, and it just doesn't start under 35, ever, but without the top, it's too cold for me too).
I don't see the coil in any of your pictures. I do see the starter, with a black/yellow wire going to the starter and a brown one hanging loose near it....
Do a search for "ignition coil ballast resistor" on google.... Apparently, with points, to make them last longer, they limited the voltage going through them? (I upgraded to electronic ignition pretty immediately after buying my FJ40 and have little interest in this issue personally). To help starting, there would be an additional wire from the starter (really, from the ignition switch to the starter and then to the coil) to provide full 12v to the coil (i.e. bypassing the resistor, more voltage to the coil, more spark).
