Differntial oil change debris
Tulsa
I was changing my rear differential oil and look what i found, along with lots of metal shavings. It was not giving me any trouble, just routine oil change. Course of action? Any idea where that piece of metal came from?
Looks normal except for that larger piece. How thick is it?
I think that is very strange. Is it very ridged or can you bend it easily?
There are these cone shaped sheet metal guides inside the axle tubes which help guide the axle shaft into the differential upon axle installation. That could be a piece of one of those. Why or how I don't know. If you have no noise coming from that differential then you are probably fine. Running it until it blows up will effectively eliminate the trouble shooting process. ;)
Fill it back up and check fill level every time you chk the air cleaner.
Now THATS the kind of trouble shooting I like!!! As long as it's YOUR ride!
