Differential re-gearing. Why?
Encinitas, CA
Hi,
After installing larger tires, what is the reason to regear the differentials? Is it only for on-road perfomance?
I have installed 33" in my FJ80 and it is a little sluggish on the road but I couldn't care less (this is not my daily driver).
I may go to 35" later on... and I'd prefer not to :wrench:, unless you guys convince me that it is necessary.
Thanks.
it's really up to you, your driving habits and the terrain you cover. I know several people running 35's with stock gears. it is a little sluggish and your MPG will suffer a little but it is still drivable.
My MPG went up when I went from 31's to 35's. :meh:
the easy answer is power at the tires. Anytime you make significant changes to the tire size it would make sense to re-gear. Most people only do this once or twice due to the expense. You will loose a good bit of your bottem end power but installing rather large tires without changing the R&P.
Drive a similar equiped vehicle thats had the gearing changed. You'll soon realize the difference in available power, less strain on drivetrain parts too.
I run 35's and know someone running 37's on stock gears. If it doesn't bother you, there's no rule that you 'need' to regear.
On that note, both of us have 5.29's on a shelf, waiting to be installed. :D
fzj w/ 35s on stock gearing was surprisingly not that sluggish. drove one between CA and Moab last year without much issue (except for a couple long uphills).
As with most modifications-- I'd suggest getting the tires you want/need, then see how the gearing feels. If you don't like it, upgrade to lower gears.
I'm running true 35x12.50's and it doesnt feel as sluggish as I thouht it was going to. It depends if you got an FZJ or an FJ too. Don't get me wrong though, 4.88 or 5.29's are on my list, just not at the top.
I think terrain and personal desire for performance will be your biggest factors.
Several of our club members are running 35's w/ stock gears but its pretty flat around here. I am on stock gears as well but plan on 4.88's one day. The kazuma gets me by on the road but it would be nice to have lower gears on the trail in low low for more throttle control.
I don't think anyone has addressed the fundamental issue here. I'm going to make up some random examples to illustrate. Let's say a stock tire is say 30" and the circumference of that tire is maybe lets just say 6' 10". So if this is your stock tire size, for every revolution of the tire your vehicle travels 6' 10".
Now you pop on 35" tires, and let's just say the circumference of these tires is 7' 2", now for every revolution of the wheel the vehicle now travels this longer (7' 2") distance BUT with the same rotation of the driveshaft. So your speedo is wrong, and you are out of the powerband that the trans/t-case/axles were designed for. And yes, it will be slow off the line, and have trouble climbing hills.
Conversely, if you put on smaller tires the truck would be faster off the line and have a lower "actual" top speed. But you have to verify these things via GPS to get accurate answers.
As an anecdotal check, just go 60 mph on the speedo, find a milemarker on the highway and time yourself, if you get to the next one in 60 seconds your gearing is pretty stock, if you make it there in say 56 seconds, you probably have big tires on and have a numerically lower final drive via as a result of the big fat tires.
Make sense?
That guy with the 37's has had those 5.29's on the shelf for around 3 years now. I'm not sure he will ever actually install them. :wrench:
LOL, he's making some noises about getting on them soon. :D
