Diff Swap
Burbank, CA
Hey Guys,
I might catch some heat for this but here goes.
I am thinking to change my car back to bone stock so that I can comfortably use it as a daily driver along with my 200. With the kids and all, I feel like my car will never hit the trails anytime soon. Plus I saw a stock one at the hardware store the other day and it got me thinking.
The biggest and most expensive challenge I have are the gears, everything else is easy. I have cryo plated 4.88s and I know its not going to be cheap to change these back to 4.10s.
I can either have a shop change them back to 4.10s and charge me an arm and a leg or trade diffs with someone, which is less labor costs and less parts costs. My car is a low mileage car, I think i have about 135k on the clock. If I were to trade diffs with a higher mileage car, would that be a problem down the line?
The gears are the only thing left for me to figure out before I start taking everything back to stock.
What do you guys think?
I think you're overthinking this. Just run what ya brung. Shelling out $$$$ for a perceived increase in reliability doesn't make a whole lot of sense, especially if you want to swap in gears with loads of miles and unknown history.
I swapped in used diffs when when I added my OEM lockers. It was very painful. In the end it was only slightly less expensive than new OEM. I should have listened to Dan. I highly advise against it.
Keep the 4.88's and just run small 33's on OEM stock setup you will be fine doing that and you won't lose a bunch of money.
Or sell your built cruiser and buy a stock truck.
Hey Guys,
sell it, and buy a stock one.
+1 to this.
The 305/70’s on the stock springs would be fine, plus staying N/A on a 1FZ the 4.88’s would be a nice feature to keep, plus if you ever decide to sell as a whole, those 4.88’s have your original receipt.
It’s not like you went to 5.29’s or have lowered the TC gears too - If your bent on going back, 33’s on stock springs look completely at home & the RPM’s are not bad even on the highway (but I don’t go over 74mph, ever).
I had 4.88’s with my 305’s /33’s for a few weeks before buying my 315’s & it was kinda awesome really - esp when we drove up to Mount Baker the ratio was enough I left the “2nd start” button engaged when we hit the snowline.
Keep-em run 33s
Funny, I've built my truck up quite a bit and now when I see pictures of it bone stock when I bought it it makes me contemplate going back to stock, peeling off the plasti-dip etc etc. I kind of like the clean look of a stock truck. I've also strongly considered going up to 4.88s so if you still consider swapping diffs I might also consider that. I had 315s now have 295/75/16s, they work well.
I'm sure alot of people will trade you stock for the 4.88
They should add cash on their side too. A good set of 4.88 will run you 1000 easy plus install.
