Diff / Lockers Swap Questions
Portland, Oregon
Website
localcred.com
I have a '97 FZJ80 in nice condition with no lockers. With prices so low on 80's right now, I'm thinking of picking up a cheap high mileage 80 with lockers and swapping them to my current ride. The goal would be to re-sell the second cruiser without the lockers after the transplant for around the same as what I bought it for.
What do you all think? Good idea/Bad idea? Things to watch out for during the operation? Best way to go about the operation? Would you recommend a full axle swap or only swapping diff components? If the donor has too many miles, should I worry about axle spindle wear?
Thanks in advance...
Since you are buying an 80 with lock axles, it will be a lot easier just to swap you non locking axles with the lock axles instead of swapping diff components. This will save you time in cutting the axles to fit the third member. This way it will save you time and money. This project is on my list and all I need are the lock axles to get mine done.
Also, if you are going to do this at home, you need a helper and bigger jack stands to at least 6 tons capacity just to be safe.
If you have both vehicles then there is no question that you would just swap the two axles. I think you have all harnesses built in that you will need as well so all you have to do is swap the axles, the elocker harnesses at the elockers (just bring them along with the axles), the switch and the elocker ECU. I guess you will have to cut the dash for the switch but I cut my 85 4Runner dash for an 80 elocker switch and it was pretty easy.
You might have to install the dash lights for the elocker "locked" lights - not sure. There are several good write-ups in the FAQ about swapping the thirds and I'm sure one or more cover the small details.
Afterthought: Not likely but if the interiors are the same color then you could just swap the dash piece with the switch. Otherwise you will have a hole to fill up in the donor 80.
Another thought: I would rebuild both of the locked axles while I was doing this swap.
Your logic that you will be able to sell the un-locked locked truck for close to what you paid for it is a false economy.
Your desire to get a locked truck means that you don't want an unlocked truck at any price. Most everyone is in your camp on that one. Who's gonna buy the truck after you remove the one thing everyone wants?
He may be able to pick up a locked rig from someone who doesn't know what lockers are worth (to certain people). This happened to me, and I got my truck cheaper than I got the Mrs. :D
Even if he gets it for a little higher, he may be able to sell it close enough to what he paid for it that it'll essentially pay for the lockers. Probably not break even or even recoup all of his costs, but probably enough to offset the costs to make it worth while.
The other option is to buy a wrecked truck with lockers. You should be able to pick it up for pretty cheap. Part it out, then sell the rest for scrap metal. That's a *LOT* of work though.
Thanks for everyone's input. Based on the responses, I think I will end up swapping the axles, switch, ECU, etc. as suggested once I find the perfect donor. Does anyone have any thoughts about axle spindle wear on the donor vehicle? Is this something that is typically addressed in an axle rebuild?
As far as...
Dan: you are awesome and I always love your input. :hillbilly: However, I paid $10k for my 1997 about eight months ago, so I wouldn't exactly say that I don't want a truck that's not locked. I love my truck, but just think it would be cool to add factory lockers.
It's not easy to find by any means, but in the past few weeks, I have found a few locked 80s in the $6k range with over 200k miles. My thinking is to play the price down to $5k, do the swap, and then try to re-sell in the $4k range. I would also do some additional elbow grease to clean up / fix up other PM issues to make the donor truck more appealing. I figure $1000 is a pretty good investment to end up with factory lockers.
:beer:
I just completed my retrofit. I wish now I had listened to Dan and purchased new diffs. The non-locking diffs I removed were in perfect condition. The used rear one whines and the front had to be rebuilt. I guess if they are in the vehicle you can test them out.
Swapping the entire housing is definitely easier in the front but the rear it is easier to modify the housing.
Don't forget you're going to have to service at least one set of axles, maybe two and one set of brakes, probably.
And, what the hell as long as you have the front shocks half way out and the springs out you might as well swap those out as well.
It will cost you more than you think.
I swapped locked axles in, and would do it again if I wasn't planning on wheeling the truck very hard. There's a design 'flaw' that makes it very difficult to remove the rear axle shaft if it gets twisted, but it hasn't happened often.
There is a blank in your dash where the switch goes, you would remove it, save it for the donor truck, and install the switch. Replace the seals and look at the bearings on the donor axles. Make sure the axles don't whine while they're still in the donor truck, say on the test drive. Big problems with these axles are rare- mine had well over 250K miles and I didn't even need wheel bearings. Doing the axle service is much easier off the truck, and will probably cost you around $300 for the two axles. You have to install light bulbs behind the dash for the locker indicators, everything else is already there. You'll have to plug in the ECU, and make or cut from the donor a part of the wiring harness that goes to the rear axle from behind the kick plate on the driver's side interior, next to the foot rest.
This isn't too difficult, and you can do a lift at the same time if you haven't already. It's nice to have the factory switch and indicators. You are buying into some possible electrical problems with the high-mileage lockers, but I'll take 'em over the o-ring and compressor problems associated with ARB lockers. Most electrical problems are with the center diff lock anyway, which you already have. Some people will tell you that the e-lockers don't actuate as fast as air lockers, but in real life it isn't a problem- as soon as the tire spins 1/5th of a revolution at most, it locks, period. The factory lockers have an indicator telling when they are activated (flashing) and when they are actually locked (solid). The air lockers have no indicator for when they are actually locked, so the folks who have them don't know that they probably don't activate 'instantly' either.
Good luck finding a donor vehicle, the market is right for it. I wouldn't worry about the donor losing value after the swap- it would if your only buyers were on this board, but the vast majority of the public has no clue what a locker is or that they were an option on the truck.
-Spike
Usually with +37 inch tires and very agressive use.
Hardly a "flaw", no?
That's why I added the quotation marks. ;) I wheel hard, and for all I know my axle shafts are now a permanent part of my rear diff, but I doubt it. I'll find out when I put in my 5.29's and +37's. :D
-Spike
why not just buy ARB lockers??
x2
Your best case scenario has the axle swap costing you $1,000. You are being VERY optimistic. Nobody can tell you those spindles are going to be bad and nobody can tell you they will be good unless you know the truck before you buy it. An unknown truck could bring some expensive surprises and having to buy a set of new birfs will make your costs rise in a heartbeat.
ARB lockers will cost you about $2,200 maybe less if you do the work. That includes F&R axle service. In any event, you will know what the job is going to cost before you get started.
-B-
There's no guarantee he doesn't need spindles in his current axles, unless I missed something.
-Spike
x3
This seems the best route to me. Unless there is a romantic side to haveing a purebred Toyota, the ARB option seems like a no brainer. Plus its a great excuse for a OBA system. :idea:
Just my $.02 This is your project, and sometimes getting there is half the fun. Good luck and keep us posted.
