Diff lock ?
Chatsworth, Ga
Okay guys, I have a 1993 80 series with all time 4WD, no diff lock switches on dash, but I have discovered what looks like wires to a diff lock, yet they have been cut and I can't find any section of wire harness that is cut or would connect. So, if it is wires to a diff lock due to possible axle replacement in the past. Can I wire it to work? Thanks!
Hard to see from that angle but it looks like there may be a diff lock actuator. Do you know if there was an axle transplant into your truck at some point?
I believe it is an axle actuator, and I don't know if it was a transplant axle. Ive only owned it about 3 weeks and the previous owner was not mechanically inclined enough to know.
Does the rear axle have a similar actuator ?
It's a sweet discovery but I would be spending my money on a rear diff lock solution before bothering with wiring up the fronts. There are not many times that you would use the fronts.
The rear has nothing like on it, just the front, so that's kinda leading me to believe that one of the previous owners done an axle swap.
well than maybe you can pick up a front and rear locked axle will all the needed parts to finish the swap and youll have a spare front. the front diff is the weaker of the two in some circumstances so having a spare is not a bad thing
Depending on your goals, intended use, a lunch box locker works well in the rear with AWD and is cheap. IIRC, the harness is still available and is affordable, combined with the switch and box would make it plug and play,,, or pray? :hillbilly:
Its possible it doesnt even work - so they swapped it into this truck since it was vestigial. Id wire up 12v to it and try to manually lock it before blowing money on anything.
Being as the "the previous owner was not mechanically inclined enough to know", the rear may already have an auto locker. If another PO took the trouble to put in a front locking axle, they must of had plans & didn't complete them. I'd put it up on jack stands & check it out. Also try nukegoat's suggestion with the front locker. Be nice to know what ya got.
Nice score!
There can be occasions where front locker only can be desirable.
It's there, I'd be saying make use of it. Front locker is going to be often better than no locker
buy a e locker setup from 12voltguy.com and then a lunchbox for the rear and you are good to go. i would not waste my time (and money) getting the factory ECU and dial when you only have the front locker.
