Hi there,
i have searched and not managed to find the specific info i am after.
i have a Japanese import 1984 BJ60 with a semi float rear end that i just got fully rebuilt after the spider gears ate themselves a few weeks ago,(that leaking pinion seal is a warning sign FYI) i also got a lock rite locker that i am about to put in (didn't turn up in time when it was all apart and on a hoist).
my mate just got his hands on a 1985 BJ60 that is basically a parts truck, but it has a full floating rear end that is mine as long as i do the swap of my axle for his to keep his drivable, it is completely unknown condition with heaps of backlash in the driveshaft and the diff seems to be leaking every fluid its ever drank but a very good upgrade for me for the price of some time and new ubolts seems like a good swap.
My questions are: will my freshly rebuilt semi float diff head be a direct bolt in to a full floater axle? obviously meaning gear ratios won't change, i won't have wasted all that money and I'm not putting in a rear end that leaks and needs a rebuild?
is there any reason the lock rite won't work also?
as i just spent a lot of money getting my diff rebuilt and my brakes are also freshly done it is only worth it to me if its a direct bolt in swap i can do in my driveway, can i remove the diff head without losing my crush washer preload or needing to adjust the diff to the new housing in any way? the brakes i can rebuild again, I've never been into a full floater before but the added security of breaking an axle and not having the wheel fall out is a bonus. if i need to have the diff setup again in the new housing then ill probably pass on it as my truck is daily driven and a necessity for work.
