Diff gaskets vs silicone
Silicone/RTV will work fine, IMHO, better than the gasket. Best to use RTV rated for gear oil, have done a bunch of them with Ultra Gray, zero problems.
If no corrosion of the mating surfaces, no left over old gasket, and assuming proper torque on the studs/nuts, any other reason a new gasket won't work? Or is it just quicker to use the FIPG and not spend the time cleaning the surfaces?
I'm sorta a hybrid - from years of being mentored by WW2 vets who were mechanics & came to my area to start & maintain petrochemical refineries, I learned to use a thin gasket with a touch of new stuff - RTV grey.
Refineries are held together the same as a car, and the paper/Grey combo is what holds together a sulfuric acid plant up here. Been on my diffs this time for ~5 yrs & both are dry.
Is there truth to the tack stage of RTV before torquing?
The paper gasket will work. In my experience, they tend to become brittle, crack, leak, have a higher chance of failure.
Paper gaskets can handle some oil, grease, etc, less clean surfaces. Done correctly, RTV/silicone should have totally clean, dry surfaces, any oil on the surfaces can prevent it adhering. So prep for RTV is more demanding, but done correctly, RTV can be longer lasting, less chance of leakage. This is one of the reasons that RTV chosen over gaskets on newer vehicles.
That trick is good for uneven gaps, like sheet metal, pans, etc. For tight gaps, machined surfaces, etc, it's not needed, I attempt to get this type together and torqued quickly as possible.
No one mentioned one of my two rules. 1) Ultra grey or black is the best, but apply, and torque asap as mentioned. 2)I always wait an hour to add oil. Lot of people forget this part, and since its rtv, and uses air to vulcanize, it takes a little while for it to fully cure in-between the 3rd and housing. I've learned through trial and error about this. My advice, get it together, put the axles back in, bleed the brakes etc etc and then add oil. Never let me down when going this route. And the paper gasket, a waste of a few dollars.
my o2, as mentioned it takes air to dry. by the time I apply the sealer and get the part up there to bolt on, I figure is enough time. oh, surfaces very clean, scraped with razor blade and sprayed with brake cleaner.
on our 85 mini trucks with the dual cases with 4.7s in the rear. I found that if I used a gasket on the rear diff, they would start to leak, and the bolts were tight. the only thing that I could figure out was, that we were either pounding the diff to hard on the rocks and moving the diff or to much torque to the diff and the gasket was ripping/moving/giving. I use the rtv black and no more leaks.
I have done it hundreds of times -for years. I let it stand about 10 min to get some air before putting together. I apply thin bead but then finger smear an even film paper this across the surface-paying extra attention around the bolt holes. CLEAN. There's no pressure unless your vent is plugged. Good time to check it. Gear lube is so thick it doesn't take anything fancy to hold it in. x2 cure before filling-when possible.
