$169 to rebuild and renozzle 4 13B-T injectors in Tucson, Novemeber 2003.
oil filters (using 41010's) are about $8 my cost.
so you use Dello or Rotella instead of Mobil 1
fuel filters (changed once) are a little more
cleanable air filter n/c
I've logged 18,000 miles on my truck in Arizona and Sonora (northern state in Mexico FYI) over the last 14 months.
I started at 70,000 miles on JDM 1987 BJ74 and so far:
-replaced the turbo gaskets ($50 and time)
-adjusted the valves
-had the timing checked at local shop
-changed the oil
I get from 20-23 US mpg, AND I get far, far, far better mileage at slow speed on ranches than any other gas truck and a majority of the torque kicks in low as well so the diesel does better at 800-1200 rpm than a gas unit, period.
If the injection pump dies, I could have it rebuilt locally (more $) or sent to BC/SK for about $800 plus parts- so far zero problems with my pump- keep the water out!.
back to a FJ40 conversion, you need to log many miles to cover the conversion costs therefore I do not believe one should convert a 40 unless its some special project that you realize those costs won't come back in the end.
-changed the oil
