Build Dick's '84 Saudi 45
Pressing wheel studs into rotor/hub
New/reconditioned parts and pieces.
Time to start the teardown on the 45 front axle.
Had great success repeating the cam/engine break-in sequence of 2000 RPM for a full 20 minutes today with a new OEM thermostat installed. Temp to 190* and no more. Used the Dakota Digital tach as the Sniper tach reading was reading too high and clearly not accurate.
Sniper was still a bit unhappy with wrong tach info and still not accessing closed loop tuning, but running smooth and strong otherwise. So., reloaded the "Wizard" settings to start over from scratch. Idle still very high with TPS and IAC at 0. Performed the "curb idle" adjustment with the ignition cycle every time to reset the TPS to 0. After a what seemed like a bazillion repetitions, achieved IAC value of 5 with TPS at 0, well within the specs of 2-10 with 3-5 ideal.
35% learning complete as closed loop was working after the adjustments
Loaded up the wife, backed up the drive, pulled back into the shop using the e-brake only as brakes are waiting for the disc swap.
Called it a first drive with the new engine and claimed a moral victory.
Getting closer to a real drive all the time.
Passenger side front axle torn down and rebuilt with the disc brake components.
Hope to complete the driver's side next week as I am done traveling for a few weeks.
A surprise box from Saudi Arabia arrived end of the week.
Turns out Meshal didn't like the look or sound of the 45's starter when he was here, so he picked up a more correct model and had it sent it to me.
What an awesome surprise from a truly generous and great guy.
Finished up the install work for the driver's side disc brake swap.
A few interesting discoveries on that side.
Evidently the birf had been previously replaced with one that was the larger diameter like the minitruck birfs that require the axle housing to be relieved to get it inserted all the way. While the passenger side required the grinding, the driver's side was already done for me. I still used the minitruck birf as the Saudi truck had front drive plates and that birf probably had more use and wear.
When I got the caliper mounted on the driver's side, after torquing the bolts, the wheel was locked up tight. Turns out the one caliper bolt that was missing and that I had ordered from Mr. T was a few millimeters too long and was binding against the rotor. The addition of 2 grade 8 washer on the caliper bolt solved that problem. The other 3 bolts, while not touching were slightly protruding from the housing, so I added single washers to them. Had to be caused by the size of the aftermarket, remanufactured calipers. Never saw this mentioned in my research.
Time to bleed the system and adjust the rear drums and the proportioning valve.
That axle housing should be good for the big birfs. That’s odd.
Yeah , I don't know why, but the 2 sides were definitely different. Fun fact to know and tell, I guess.
Blake bleeding complete, finally.
I had one new flare on a stock line that I reconfigured to (almost) work that would not seal up. I had attempted it in the very cramped and busy space in the engine bay and could not make it happen. The stock Toyota brake lines are hell for stout, so I find them pretty unforgiving to flare without perfect access.
My solution was to remove the air cleaner and get all of the electrical and hoses off of the firewall and out of the way so I could remove the brake line supports across the firewall all the way to the junction on the passenger side frame rail. This got enough wiggle room to move the offending line where I could trim it, flare it, attach a splice and add a new line to the master cylinder. I used copper-nickel line which is a lot softer and easier to work with. The line I bought was 20 " with flares and M10x1 tube nuts on both ends. I used the M10x1 nut on the master cylinder, and cut and flared a 3/8x24 nut for the splice end.
Bleeding was the usual pain. Between the harbor freight vacuum bleeder, my wife's strong legs, the correct adjustment on the rear drums, and a bunch of passes through the bleeding sequence, it was done.
The Saudi starter is installed. It is definitely smoother and quieter than the after market version, but I don't get to listen much as the Sniper fires up so fast.:grinpimp:
I drove about 40 miles of paved roads close to the house yesterday to shake things out. The Sniper was pretty rough at first, struggling with idle and acceleration, but after it got to temp and started learning, things got real good, real fast. I felt so confident that I drove 7 miles to see my friend who has helped me a bunch over the years so he could finally see the truck drivable. All was good, until we got in for the test ride.
The clutch pedal went to the floor, and fluid was dribbling out of the relief hole on the slave cylinder boot. We tore the brand new slave cylinder out, which was a challenge because the piston had overextended and was jambed crookedly outside the cylinder bore under a bunch of pressure from the clutch fork. Turns out the jamb nut that locks the rod length had loosened and the rod adjustment had shortened enough that the piston was pushed out of the bore.
A quick trip back to my shop and we found the slave cylinder spare parts pile. We robbed a piston and seal which was in good shape and put it in the bore of the almost brand new one that the aluminum piston had not damaged. Back to Wayne's house and an install, bleed, adjustment, and uneventful drive home.
Today, the jamb nut gets a healthy dose of locktite and a good tightening better than I evidently did last time.
Nothing exciting happening on the build right. I am in the "test drive with cell phone coverage to build confidence stage " now and sort out issues as they appear. Drove about 70 miles from one end of the valley to the other and had no real issues, just the following items.
Driver's side seat slider stuck and spit out a mystery part, wouldn't adjust all the way back and then started rocking front to back. I ended up reinserting the "adjustable screw driver blade" that I had removed when the seats went to the upholsterer, but with a bend so it was removable and able to be adjusted. Not elegant, but functional.
Next was the "hyper speed " blink on the turn signals. I had started to address this when the front main bearing seized (almost a year ago). After a bunch of research and some really bad AI info, the cure was replacing the new stock flasher with an old school 255 mechanical one.
My success with the turn signals didn't last very long. I still had intermittent problems with a few blinks and then a solid indicator with no flash at the signals after a period of good function. This random occurrence made me believe that the 41 year old flasher unit (81980-30040) was probably the culprit, so I ordered the available replacement substitute (91980-12H04) and installed it. So far, so good except the turn signal flash period is faster than the more normal period of the hazard. We will see how this does over the coming weeks.
The door mounted rear view mirrors would flop around in the breeze while driving. The solution was to tear the mount apart and add a washer above the tension spring on the arm in the mount as there were pieces of the old disintegrated plastic washers in the body of the door mount. And clean out the ton of Fluid Film that had been soaking in there.
Finally, a quick adjustment on the rear drums per MUD wisdom fixed the slightly wonky braking.
Ready for the next phase, a drive today on some rough forest service roads to a hike to a beautiful high lake, with the option to return on a mild 4WD drive road if the drive up goes well.
Test drive was a great success. Bounced around in the dirt and exercised locking hubs and 4WD high and low ranges with no issues.
Had a beautiful hike except for the lack of Colorado's impossibly blue skies due to the smoke from the wildfires in Utah.
The only mechanical issue was an extremely pressurized fuel tank when I got home and a high 1200 RPM idle . I heard a small hiss which became a large one complete with fuel bubbling when I took the gas cap off. After research and testing, I ordered an AC Delco charcoal canister and a purge valve per @wngrog to replumb the tank/canister/Sniper vacuum venting and hopefully cure the issue. The old canister was plugged up, so I think this will solve the problem. The high idle disappeared as soon as the pressure was off of the tank.
So I installed the AC Delco (GM 215-153) charcoal canister. It was larger than the stock one, but I got lucky and was able to rework the factory band to work without a lot of drama on the factory mount. The only purge valve I was able to find was one that was a cross referenced with the AC Delco 214-552 that others have used. It was Standard Motor Products CP112. The small "trigger port" of the valve was installed tee'd into the distributor vacuum advance hose which went to the ported vacuum port on the Sniper. A hose on the the purge port on the canister was connected through the the large bottom ports of the valve and run to the 3/16" manifold vacuum port on the Sniper. The fuel tank vapor line from the fuel tank connected to the tank port on the canister.
And I am still getting pressure in the fuel tank.
I have blown air through the fuel vapor line at the canister back to the fuel tank and it pressurizes the tank, so I don't think that there is any blockage there. Any ideas/suggestions would be appreciated before I break down and drill a hole in the gas cap to relieve the pressure.
A small but satisfying victory today. Finally got organized and got the fuel sender programmed.
Every time I got in the truck the Dakota Digital asked me to program the fuel sender. To see the trip odometer ( which was my gas gauge at that point) I had to reset switch S1. Every time I turned the key.
I wanted a 2 gallon reserve so I needed to show up at the gas pump with 2 gallons in the tank for the empty setting and add 6 gallons for 1/3, another 6 for 2/3, and a final fill to full which should have been another 6, but was 7 instead. Made sense as 80 liters is 21 gallons, but I was working off of 20 gallons as that was what it took to fill it the first time I ran out and added "about a gallon or so" from the fuel can in the back of the truck to get to the Maverick station to fill it and confirm the tank size. Plenty close enough for the accuracy of the system components and the bottom end of the scale is the most important.
Next item to rear it's ugly head is an issue with excessive heat and high temps in the engine bay.
While both the Dakota Digital and Sniper show engine temps to be right at 190 degrees (stock OEM 190* thermostat) when driving, at idle they climb slightly and the engine bay gets so hot that you cannot touch almost anything metal. Neither the 40 or the 60 are like this.
Since the 45's cooling system is 100% new parts and the problem is worse at idle, after research I believe that the heat issue is an airflow problem caused by the fan being completely inside the shroud. Both my 40 and 60 have 1/3 to 1/2 of the fan blade outside the shroud, and have no issue with engine bay heat.
The fan is farther forward into the shroud because I replaced the original non fan clutch with a new water pump/fan clutch/fan blade assembly that moved the fan forward about 1 inch -see post 77 of this thread.
I will not have time in the next week to work on this, so in the mean time, I look forward to some good MUD input.
