Detroit locker exploding
I've heard rumours that detroit lockers (not the ones that are the same design as the lockrights, the others) break when 1 axle shaft lets go under power. is this true. i've got one i want to throw in the front of the cruiser (and weld the rear) but with toyota cv's being toyota cv's, i don't want to turn the locker into an expensive paperweight.
You will be fine.
Most of the Detroits explode with moly shafts..
FI you are that concerned about it, get a ARB. And pray that you do not have issues when you truly need it.
nah, don't have the funds for an ARB, hence the detroit in the front, welded in the rear
i take it they explode with the moly shafts because there is a huge shock loading when one of them finally let go?
When I engage my front OME the steering becomes difficult at best with power steering. What steering issues are you dealing with when you have an automatic locker in the front. I would think you would be fighting the front end every time the locker engages from mismatched wheel rotation. Maybe I just do not understand how a Detroit locker functions in a front axle.
Millhouse removed all the teeth from a Detroit HP 8" Toyota when breaking a stock inner up front in his buggy....
Detroit lockers are garbage......I would weld the diff before I ever put a penny into a Detroit...
All auto lockers allow 1 wheel to rotate or ratchet faster all the time (in the direction that the ring gear is driven) than the ring gear, while the other wheel rotates at the same speed as the ring gear. Both sides only "lock" when a wheel slips. This means that the inside wheel in a turn will have a wheel speed mismatch with the rear that will cause under steer and try to make the wheel go straight. This is less than half the amount of wheel mismatch force you get with an ARB or spool, where both wheels turn the same speed as the ring gear and the two front wheels have a speed mismatch with each other and the rear.
I have seen reports on pirate4x4 of ARBs grenading in a similar fashion when an inner snaps. Apparently this puts some pretty severe shock loading on the carrier.
I would be very interested in reading about these Charlie. I am aware of the Dana 35C rear ARB being ruined when an axle shaft fails, but have not heard of a 9”, Dana 60, or Land Cruiser/Mini ARB unit failing because of a shock load.
If you have links, please post them up!
:beer:
I think you are mistaken, the only reports I have ever read on there about broken lockers when a shaft breaks is a Detroit, not ARB.
