Deleting ABS
Southern Maine
I have a 1997 and the ABS sensors are in bad shape. One of them is so bad it occasionally activates when braking. I did some searching and was not able to find much on this on MUD (maybe I am looking in the wrong spot). Anyway, was looking for input from those that have done the removal and install of Wits End plugs. How do folks like this? I do about 85% on road driving.
Many thanks,
Why not just keep the sensors in and pull the ABS relay?
Thanks Squeegee, one of the options for sure. Follow up question, if I just unplug the line that connects to the ABS unit will that work as well or will it sense a fault and light up my dash warning?
You pull the fuse then unplug the sensor. Then pull the bulb. All this is free, or buy a kit pull the fuse , unplug the sensor and pull the bulb
10-4 makes sense. ;)
Ajax nailed it
