deleted
Vacuum reservoirs are used to supplement brake booster vacuum and should be positioned close to the booster. If two smaller units fit the space better, I don't see an issue with using two.
Try to keep the lines between them as large as possible. Vacuum needs larger diameter plumbing than pressure to get the same flow rate.
