Ordered 4 new Toyota OEM globes from http://www.amayama.com/. They were about $625 for ALL FOUR, plus $150 shipping from Japan. Took about 3 weeks to get here. I am very pleased!
OK, found it on here:
Front 6.9 +/- 0.5 mpa --> mine is way out with 8.9
Rear 5.6 -- 6.7 mpa--> mine is way out with 7.6
I have to find a 30mm socket and adjust the torsion bars and see if I can get it down a bit.
From memory the fluid is 2 years old, around 20,000 kms.
I have to check the invoices though. It was done before I bought the car.
Car has now 243,300 kms on the clock.
What do you mean by "then adjust for mid spec"?
Try and achieve 6.9 front, 6.2 rear with vehicle unladen, full tanks of fuel, on level ground and wheels pointing straight ahead. Sent from my iPhone using IH8MUD
And still have a working AHC?
Another thing.
Is it normal that with the cable attached the ABS is on?
Also after disconecting ths VSC TRC and VSC OFF lights are on.
Is there a sequence of connecting the cable? First laptop running, engibe on, connect cable?
Code cleared and oil is draining.
Can't see how to change the steering valeu. Also the only item I can change in customising is the tilting of the steering wheel.
