Haven't seen such a rust free cruiser since 2001.
Yes, those are the bolts.
The piston type accumulator is only used to quickly raise the vehicle height. it doesn't effect ride comfort or handling the way the diaphragm accumulators/globes do so (as far as i know) there's nothing to adjust and nothing to worry about there as long as it works. I don't remember seeing a spec for the pressue but i do remember mine always being 10+ after it has been refilled (ie after the pump has stopped runnig, say maybe 30 seconds after raised to N).dealmaker said:One thing to note, a month ago my Accumulator Pressure Sensor read 8.5.
Today it read 10.4. It would be nice to know if that is in spec and what the spec range is for that, if anyone knows.
Second time this week that I can't find info I know is here. What are the FSM recommended settings for neutral pressure for front and rear. I am hoping to make all adjustments this weekend. Thanks in advance.
PADDO - Thanks, using what reader? Is there a difference?
I have seen a number of references to a steering angle reset here. I have searched and cannot find how it is done. Is there a good detail on performing a steering angle reset? Is is done in the Techstream software or by shorting pins in the connector?
Download the software. There was a linky in here somwhere.So, I bought this cable an disc a while ago and just tried to use it. My computer would not recognize the disc. It thought it was blank. Any thoughts?
I've only done it in TechStream, a couple of clicks on the laptop, easy. IIRC there is also a procedure in the FSM to do it via shorting terminals, can't remember which section though, steering chapter would be the logical place to start I suppose. It's basically unlock steering actuator, recentre wheel, relock actuator, let system self recalibrate for 5 seconds.
Sent from my iPhone using IH8MUD
